Introduction
Document UnderstandingTM is the main starting point for creating and managing projects.
You can use Document Understanding for structured or semi-structured documents, and also enlist the help of pre-trained models. You can always start a training session from scratch, validate your documents, and customize the projects as needed.
Projects list
After creating a project, you can open it from the Projects section. This section presents a list with all created projects. You can sort the list:
- Alphabetically in ascending order.
- Alphabetically in descending order.
- By creation date. This is the default sorting order.
You can use the Columns option to customize the amount of details available for the projects list. You can customize the following details:
- Name: displays the name of the project.
- Document types: displays the type of documents used for each project.
- Creation date: displays the creation date for each project.
- Refresh: Refreshes the information in the displayed columns for all projects.
You can choose which columns are displayed from the Columns ˅ drop-down menu. If you select Reset, all fields will be displayed, no matter of the previous selections.
Project page
After selecting the project you want to work on, the project page opens.
Each project page has four sections:
- Build: Upload documents, train document classification and extraction models, and receive recommended next steps for improving model performance.
- Measure: Review the overall status of your project and verify the performance of classification and extraction models.
- Publish: Publish a version of the project containing the models, consume the models using activities or APIs.
- Monitor: Review the performance metrics of your automation, and view an audit trail of processed documents.
You can use keyboard shortcuts to navigate through your Document Understanding modern project. To check the available shortcuts and either enable or enable keyboard shortcuts, select the Keyboard shortcuts button located at the bottom left corner of the screen.
