Skip to main content
Configuring consent prompts
As an administrator, you can establish consent prompts for users logging into your organization. These prompts ensure each user is informed about internal policies they need to consent to before they can use Private Private Test Cloud.
For record-keeping, you have access to detailed logs for each consent interaction. These logs capture the identity of the logged-in user, the login date, whether they accepted or rejected the prompt, and the expiry date of an accepted consent. The expiration of an accepted consent does not disconnect the user, however, they are prompted to confirm their consent again with their next login.
Users who choose to decline are prevented from logging in, but have the option to accept the consent if they reconsider.
To configure a consent prompt, follow these steps:
  1. Navigate to Admin > User Consent for your organization.
  2. Select Create user consent to create a new consent. The Create user consent window is displayed. On the left side you can configure your consent prompt. On the right side, you can notice a real-time preview of your consent prompt.
    note
    You can only configure one consent prompt per organization.
  3. Set a title in the Title field. Provide a short, clear summary of the policy content for which users are to provide their consent.
  4. Add the content in the Content field. You should detail the specific policies the user needs to consent to. You can format your messages as needed, and you can incorporate tables using Markdown.
    note
    Copying and pasting a markdown table directly into the Content field does not render as a table but maintains the raw markdown syntax. For correct table rendering, either delete the last character of the copied text after pasting and then add it back, or manually enter the entire table.
  5. Enter the text for the radio buttons defined for consenting and declining options
    • On the Radio button - consent field, enter the text for the consenting option. This option allows users to use the platform.
    • On the Radio button - decline field, enter the text for the declining option. This option prevents users from using the platform. Users who choose to decline have the option to agree if they reconsider.
  6. Under Settings, select your preferred Recurrence option:
    • Choose Once to show the consent prompt a single time.
    • Choose Repeat to configure recurring prompts. You can set the frequency intervals to specific days, weeks, months, or years as needed. The expiration of set recurring time does not disconnect the user, however, they are prompted to confirm their consent again with their next login.
  7. Select Save to keep your changes.
To edit an existing consent prompt, follow these steps:
  2. Select Edit user consent to edit the existing consent. The Edit user consent window is displayed. On the left side you can configure your consent prompt. On the right side, you can notice a real-time preview of your consent prompt.
  3. Make the necessary edits to your consent prompt. For details about the available options, refer to Configuring a consent prompt.
  4. Select Save to keep your changes. The Content changes window is displayed, where you can choose to keep the existing user records from the initial consent prompt, or to reset the record.
    'Content changes' image
  5. Select Keep existing user records and only prompt new message to users who have not yet accepted to keep existing user records, or Delete existing user records and re-prompt new message to all users to delete existing user records and require all users to accept the edited consent prompt.
Deleting a consent prompt erases the consent records, requiring all users to accept any newly created prompts again. To delete a consent prompt, follow these steps:
  1. Navigate to Admin > User Consent for your organization. The User consent window is displayed showing an overview of the existing consent prompt.
    'User consent window' image
  2. Select Delete to delete the existing prompt. The Delete user consent window is displayed.
  3. Select Delete to confirm deleting the consent prompt or Cancel to return to the User consent window without deleting the prompt.
