Accounting quality control
Accounting quality control is the dashboard where you can analyze your process regarding accounting quality. It enables you to analyze purchase order items labeled with one or more maverick buying tag.
Accounting quality control overview
Check out KPIs for a detailed description of the KPIs related to accounting quality.
Dashboard charts
The following table describes the dashboard charts of the Accounting quality control dashboard.
| Chart | Description |
| Matching control | A bar chart that provides an overview of how accounting documents match with corresponding purchase orders and goods receipts. It highlights the 2-way and 3-way match rates per supplier, helping identify missing or inconsistent data in the matching. It helps identify suppliers or documents with matching discrepancies that may require review. |
| Potential duplicates | Displays accounting documents that may have duplicates, listing potential duplicate invoices or accounting records with exact or near matches to support data accuracy and prevent duplicate payments. |
| Trends | The graph on the Trend chart shows the values of the selected metric over time, based on the Accounting document creation timestamp. |
note
You can select different metrics and fields to change the context.
