Skip to main content
Integrated extractors
Generic
Message: An instance terminated unexpectedly. Job was cancelled.
Possible solution
Contact UiPath Support for help.
Message: Required tables (or fields) not accessible from source.
Possible cause
The root cause of this error is the lack of table or field level access for the user configured in the extraction connection.
Possible solution
Either remove the table or field or ensure the user has access to all tables and fields selected for the data extraction.
Message: Table([TableName]): Deleted intermediate tables but no new files found. Failed loading data into table [TableName].
Possible cause
When you try to extract data from a source system using a direct connection and a table does not have any data associated with it, the following message can occur.
The following illustration shows an example.
Example of the error message
Possible solution
  1. Go to Data transformations.
  2. In File storage manager, delete the tables.
  3. Configure a direct connection and make sure the table is set as non-mandatory.
    Manadatory option for an input table
Salesforce connection
Message: [0] [sf:OPERATION_TOO_LARGE] OPERATION_TOO_LARGE: exceeded 100000 distinct ids.
Possible cause
The root cause of this error is the lack of a specific permission (View All Data) for the user configured in the extraction connection.
Possible solution
  1. Reduce your date range filter to extract less data.
Refer to Error 'Delete Operation Too Large' or too slow when you delete records in the official Salesforce documentation for a detailed description of the resolution for this error.
Some fields are missing from the extraction fields mapping screen
Possible cause
The Salesforce user profile or permission set may not have access to the fields.
Possible solution
  1. Verify if the missing fields exist in Salesforce.
  2. Verify the Field-Level Security settings and the Field permissions assigned to the user profile in Salesforce.
Refer to Set Field Permissions in Permission Sets and Profiles and Field permissions in the official Salesforce documentation for more information on field permissions in Salesforce.
Message: Required tables not accessible from source. blng__CreditNote__History, blng__CreditNote__c, blng__CreditNoteAllocation__c …
Possible cause
The root cause of this error is that Salesforce Billing package is not installed or the user configured in the extraction connection does not have access to its tables.
Possible solutions
  1. Check whether the Salesforce Billing package is installed.
  2. Make sure the user configured in the extraction connection has access to the tables and fields specified in the app template. Refer to App Templates for details.
Message: Required tables not accessible from source. SBQQ__Quote__History, SBQQ__Quote__c
Possible cause
The root cause of this error is that Salesforce CPQ package is not installed or the user configured in the extraction connection does not have access to its tables.
Possible solutions
  1. Check whether the Salesforce CPQ package is installed.
