Create a destination connection
Setup credentials for Azure Blob
To set up an Azure Blob destination connection, you need the following setup credentials for the Azure Blob.
accountURIazure shared access signature (SAS uri)
These credentials are located in the url of the Azure blob storage to which the extracted data needs to be uploaded.
Check out Retrieving the credentials for the Azure blob storage.
Setup the Azure Blob destination connection
Follow these steps to create the Azure Blob destination connection.
| Step | Action |
| 1 | Define a new connection of type Azure Blob . |
| 2 | Enter a descriptive name for the destination connection. For example, AzureBlob_IM . |
| 3 |
| 4 |
| 5 | Create and test the connection. |
