Skip to main content
Running an extraction
note
The Use on-premise data extractor option is only available for process apps created from:
  • an SAP source system app template.
  • a Custom process app template.
  • an Event log app template.
You can select the Use on-premise data extrator option to load data from your SAP system. The UiPath on-premises data extractor is a standalone application that can be installed on your local machine. It will connect to your SAP system or SQL Server and extract data from it.
  1. In the Connection step, select the data source created with the UiPath on-premises data extractor, and select Next.
  2. In the Extraction settings, configure the Date range for the extraction, then select Next. The Extraction tables page opens, displaying the list of tables that are defined in the app template, which are extracted by default.
  3. Configure the Extraction tables and, optionally, add new tables. Check out Mapping input tables.
  4. Select Next.
  5. Configure the Extraction fields and, optionally, add new fields. Check out Mapping input fields.
  6. Select Next.
Refer to Selecting the data source for more information.
Troubleshooting
Installation issues
In case you encounter failures, you can check the logs specified in the LogFilePath setting for any failures. If no destination path is defined, you can review the logs located in the /Logs folder.
Timeout issues when executing RFCs in SAP
In case you experience timeout issues when executing RFCs in SAP, you may need to extend the timeout limits in your SAP instance. Refer to the official Theobald documentation on Xtract Table - Time Limit Exceeded for more information on how to extend timeout limits.
