Access to Automation Suite
To start using the Process Mining service you need an Automation Suite account. Check out About accounts for more details.
Tenants and services
The Process Mining service that allows you to manage and set up process apps must be enabled on each of the tenants where the Process Mining service will be used.
Process Mining is a tenant-level service signifying that each tenant's data is segregated. This means that you need to enable the service for each of the tenants where this is needed.
Changing localization settings
The default language is English. The language can either be changed globally, with the change being propagated to all the users accessing your organization, or at a local level, for yourself only.
Process Mining App templates are not localized.
Check out Changing localization settings for more information.
