Skip to main content
Configuring the extraction script
Follow these steps to configure the extraction script.
  1. Go to the App Templates page and open the documentation page for your app template.
  2. Locate the section Loading data using Theobald Xtract Universal and download the extract_theobald_as.zip file for your app template. This extract_theobald_as.zip file contains the extract_theobald.ps1 script and the config.json file.
  3. Unzip the content of the extract_theobald_as.zip file on the server where Theobald Xtract Universal is installed.
  4. Configure the variables for the script in the config.json as listed in the following table.
Variable
xu_location
The Xtract Universal installation folder. This is the folder where you can find the xu.exe . For example: C:\\MyFolder.
xu_server
Address of the server where Xtract Universal is installed. The default is localhost .
xu_port
Port of the server where Xtract Universal is installed. The default port of an installation is 8065 .
end_of_upload_api
The API that is called to start data processing in Process Mining, once all data has been uploaded. Refer to Retrieving the SQL Server database parameters
extraction_start_date * Start date to be used to limit extractions. Only tables where a date filter is applied are filtered on this date. Format is YYYYMMDD . The default is no limitation indicated by the start date 19700101 .
Note:
  • extraction_start_date must have a value.
  • all events that happened before extraction_start_date   will  be excluded from the extracted data.
extraction_end_date * End date to be used to limit extractions. Only tables where a date filter is applied are filtered on this date. Format is YYYYMMDD . The default is no limitation indicated by the end date 20991231 .
Note:
  • extraction_end_date must have a value.
  • all events that happened after extraction_end_date   will  be excluded from the extracted data.
language
The language in which data is extracted from the source system. The default is E .
exchange_rate_type
The exchange rate type that is used for currency conversion. The default is M .
is_sap_hana Specifies if the source system is SAP HANA. Other versions of SAP might give errors in the extraction because of clustered tables. The default value is true .
*) To achieve a more complete overview of all events, it is recommended to set extraction_start_date and extraction_end_date so that the interval exceeds twice the known throughput time of the business process.
