Skip to main content
Donut charts
Introduction
Donut charts can be used to compare the relative proportions of a certain metric within a category. The data in a donut chart is displayed in slices that form a circular graph. Each slice of the donut is relative to the size of the category used for the chart. The entire chart represents the total (number or 100%) of the category, while each slice represents a part of the total. The hole in the center of the donut chart shows the total value of a different metric to provide a context for the main metric. The following illustration shows an example of a donut chart.
Donut chart example
A legend is automatically generated for a donut chart.
Properties
You can edit the properties of a donut chart in the Edit donut chart panel.
The following table describes the properties of the Donut chart.
Element
Title
Text box that enables you to edit the title of the donut chart.
Tooltip
Text box that enables you add a text that will be displayed as tooltip when the user hovers the mouse over the chart title in the published process app.
Category
List box that enables you to select the category used for the slices on the donut chart.
Metrics
List of metrics that define the values displayed on the slices.
  • Use the Add metric option to select one or more metrics that will be added to the metric selector.
  • Drag and drop the metrics in the list to arrange the metrics as desired.
Note:
You must at least select one metric. If you select multiple metrics, the first metric will be displayed by default.
Center metric
List box that enables you to select the metric to be used for the hole in the center of the donut chart.
Maximum number of slices
A donut chart displays up to six slices. If the data consists of more than five slices for the selected category, a sixth slice is displayed representing the combined total of the remaining categories that are not displayed individually.
The purpose of the sixth slice is to provide a complete picture of the data distribution, when not all categories are displayed individually. It shows the proportion of the data that is not covered by the top 5 individual categories in comparison to the whole.
