Transformations
Folder structure
The information on this page is only applicable for app templates that have a due dates configuration files and a seeds\ folder.
The transformations of a process app consist of a dbt project. The following table describes the contents of a dbt project folder.
| Folder/file | Contains |
dbt_packages\ | the pm_utils package and its macros. |
macros\ | optional folder for custom macros |
models\ | .sql files that define the transformations. |
models\schema\ | .yml files that define tests on the data. |
seeds | .csv files with configuration settings. |
dbt_project.yml | the settings of the dbtproject. |
The Event log and Custom process app templates have a simplified data transformations structure. Process apps created with these app templates do not have this folder structure.
dbt_project.yml
The dbt_project.yml file contains settings of the dbt project which defines your transformations. The vars section contains variables that are used in the transformations.
Date/time format
Each app template contains variables that determine the format for parsing date/time data. These variables have to be adjusted if the input data has a different date/time format than expected.
Data transformations
The data transformations are defined in .sql files in the models\ directory. The data transformations are organized in a standard set of sub directories.
Check out Structure of transformations for more information.
The .sql files are written in Jinja SQL, which allows you to insert Jinja statements inside plain SQL queries. When dbt runs all .sql files, each .sql file results in a new view or table in the database.
Typically, the .sql files have the following structure: Select * from {{ ref('Table_A') }} Table_A.
The following code shows an example SQL query.
select
tableA."Field_1" as "Alias_1",
tableA."Field_2",
tableA."Field_3"
from {{ ref('tableA') }} as tableA
In some cases, for process apps created with earlier versions of the app templates, the .sql files have the following structure:
- With statements: One or more with statements to include the required sub tables.
{{ ref(‘My_table) }}refers to table defined by another .sql file.{{ source(var("schema_sources"), 'My_table') }}refers to an input table.
Main query: The query that defines the new table.
Final query: Typically a query like
Select * from tableis used at the end. This makes it easy to make sub-selections while debugging.
For more tips on how to write transformations effectively, refer to Tips for writing SQL.
Adding source tables
To add a new source table to the dbt project, it must be listed in models\schema\sources.yml. This way, other models can refer to it by using {{ source(var("schema_sources"), 'My_table') }}. The following illustration shows an example.
Each new source table must be listed in sources.yml.
For more detailed information, refer to the official dbt documentation on Sources.
Data output
The data transformations must output the data model that is required by the corresponding app; each expected table and field must be present.
If you want to add new fields to you process app, you can add these fields in the transformations.
Dbt deprecation warning
The security updates for Process Mining on 2.2510 required upgrading to a newer version of dbt. In this version, the following dbt deprecation warning may appear when running an ingestion or data run from the Data Transformations editor if you are using a process app created with a Process Mining version prior to 2024.10.6:
[MissingArgumentsPropertyInGenericTestDeprecation]: Deprecated functionality
Found top-level arguments to test `pm_utils.<function-name>`. Arguments to generic
tests should be nested under the `arguments` property.`
For new process apps, this warning message will not be displayed. However, the warning may still appear in existing process apps. In such cases, make sure that arguments to tests are specified under the new arguments property. Example: Old (deprecated): assignment
- pm_utils.not_null:
severity: warn
New (corrected): assignment
arguments:
severity: warn
Refer to the official dbt documentation on MissingArgumentsPropertyInGenericTestDeprecation or more information and a detailed description of how to resolve this issue.
Macros
Macros make it easy to reuse common SQL constructions. For detailed information, refer to the official dbt documentation on Jinja macros.
pm_utils
The pm-utils package contains a set of macros that are typically used in Process Mining transformations. For more info about the pm_utils macros, check out ProcessMining-pm-utils.
The following illustration shows an example of Jinja code calling the pm_utils.optional() macro.
Seeds
Seeds are csv files that are used to add data tables to your transformations. For detailed information, refer to the official dbt documentation on jinja seeds.
In Process Mining, this is typically used to make it easy to configure mappings in your transformations.
After editing seed files, run the file by selecting Run file or Run all, to update the corresponding data table.
Check out Activity Configuration: Defining activity order and Simulating automation potential for examples of using seeds files.
Tests
The models\schema\ folder contains a set of .yml files that define tests. These validate the structure and contents of the expected data. For detailed information, refer to the official dbt documentation on tests.
When you edit transformations, make sure to update the tests accordingly. The tests can be removed if desired.
Dbt projects
Data transformations are used to transform input data into data suitable for Process Mining. The transformations in Process Mining are written as dbt projects.
This pages gives an introduction to dbt. For more detailed information, refer to the official dbt documentation.
pm-utils package
Process Mining app templates come with a dbt package called pm_utils. This pm-utils package contains utility functions and macros for Process Mining dbt projects. For more info about the pm_utils , refer to ProcessMining-pm-utils.
Updating the pm-utils version used for your app template
UiPath® constantly improves the pm-utils package by adding new functions.
When a new version of the pm-utils package is released, you are advised to update the version used in your transformations, to make sure that you make use of the latest functions and macros of the pm-utils package.
You find the version number of the latest version of the pm-utils package in the Releases panel of the ProcessMining-pm-utils.
Follow these steps to update the pm-utils version in your transformations.
- Download the source code (zip) from the release of
pm-utils. - Extract the
zipfile and rename to folder to pm_utils. - Export transformations from the inline Data transformations editor and extract the files.
- Replace the pm_utils folder from the exported transformations with the new pm_utils folder.
- Zip the contents of the transformations again and import them in the Data transformations editor.
