Skip to main content
Incremental extraction
For most source systems, CData Sync has preconfigured how incremental extractions should be performed. If that's not the case, the settings have to be edited manually to perform incremental extractions. For more on how to do this, refer to the official CData Sync documentation.
Introduction
Depending on your source system, it is possible to run incremental data extraction with CData Sync.
Incremental extraction schema
Check incremental settings
Running incremental extraction
Check out Run the job for information on how to start the extraction job.
The first time the CData Sync extraction job runs, a full extraction is performed and all source data is extracted. Every next time the CData Sync extraction job runs, only the data that has changed in the source is extracted and the delta is added to the already extracted data.
For more information on incremental data extraction with CData Sync, refer to the official CData Sync documentation.
