Installing CData Sync
For information on installing and running CData Sync, refer to the official CData Sync - Getting Started documentation.
For more information on system requirements for CData Sync, refer to the official CData Sync - Installation and Configuration documentation.
For a POC, you can request CData for a Free Trial version of CData Sync. Go to the official CData Sync website to sign up and download CData-Sync - Free Trial.
To install CData Sync, you need a valid license. The license is provided via UiPath® for the purpose of Process Mining. If you already have a previous version of CData Sync installed, it is recommended to uninstall the previous version first. Any defined jobs/connections will be retained.
Follow these steps to install CData Sync.
- Download the CData Sync Windows installer (
setup.exe) using the following link: CData Sync Windows 25.2.9369. - Run the downloaded
setup.exeand accept the default settings.
If CData Sync is not started automatically in the last step of the installation, CData Sync can be reached at http://localhost:8181/. 3. Enter a password for the admin user.
After successful installation of CData Sync:
- Create a user account for each developer.
- Set up CData Sync to run as a service, to make sure CData Sync automatically starts up when booting the machine. Refer to the official CData Sync documentation for more information on how to run CData Sync as a service.
To set up an extraction using CData Sync, check out Loading data using CData Sync.
You can transfer a CData Sync license from one machine to another. Refer to the official CData Sync documentation for more information.
Upgrading CData Sync
To upgrade CData Sync to a new major version, you need a valid license. The license is provided via UiPath® for the purpose of Process Mining.
If you encounter data loading issues, performance, or stability issues using CData Sync 2024, it is strongly recommended to upgrade to CData Sync 25.2.9369.
Workspace Management
CData Sync 25.2.9369 includes Workspace Management. Workspaces allow you to organize connections, jobs, and access policies, and make it possible to restrict user access to specific connections or jobs. If your organization requires access management on data connections, you should upgrade to CData Sync 25.2.9369.
Check out the official CData Sync documentation on Workspace Management for more information.
Performing an upgrade
If you already have a previous version of CData Sync installed, you need to stop the CData Sync version first. Any defined jobs/connections will be retained.
Check out the official CData Sync documentation on Software Upgrades for more information on how to upgrade from an earlier version.
When you upgrade to a new major version of CData Sync, existing connections may continue using the old connector version. If you encounter issues, you can switch to the new connector version by creating a new connection and configuring it in the same way as the old one. The connector version is displayed in the connection details. If you want to use the new connection in an existing job, you need to clone the job and update it to point to the new connection. Note that the Insert Mode setting has moved from the Destination connection to the Advanced settings of a job. Check if this setting is set to SingleFile.
