Purchase-to-Pay input fields
Introduction
This section contains an overview of the fields for each of the input tables of Purchase-to-Pay. For each object the fields are listed. For each field, the name and a data type are displayed. Apart from that, it is indicated whether the field is mandatory if the object is included in the Purchase-to-Pay process.
Optional tables should be part of the input, but may contain no records. When a field is mandatory, it should not contain NULL values.
| Object | Table | Mandatory Y/N |
| Purchase requisition | Purchase_requisitions | N |
| Purchase order | Purchase_orders | Y |
| Purchase order item | Purchase_order_items | Y |
| Goods receipt | Goods_receipt | N |
| Invoice | Invoices | N |
| Invoice item | Invoice_items | N |
| Accounting | Accounting_documents | N |
| Payment | Payments | N |
| Events* | Event | Y |
*) Events is not an object of the Purchase-to-Pay process, but an events table is mandatory for a correct working of the Purchase-to-Pay process app.
The following illustration shows the relations between objects of Purchase-to-Pay.
Table names and field names are case-sensitive. Always make sure that the field names (column headers) in your dataset match the field names (in English) in the following tables and that the file names match the table names.
Field types
The following table describes the different field types and their default format settings.
| Field type | Format |
| boolean | true, false, 1, 0 |
| date | yyyy-mm-dd |
| datetime | yyyy-mm-dd hh:mm:ss[.ms], where [.ms] is optional. Refer to the official Microsoft documentation if you want to change the date format. |
| double | Decimal separator: . (dot) Thousand separator: none |
| integer | Thousand separator: none |
| text | N/A |
Purchase_requisitions_base_raw
The following table describes the fields of the Purchase_requisitions_base_raw table.
| Name | Data type | Mandatory Y/N | Description |
Purchase_requisition_ID | text | Y | The unique identifier of the purchase requisition. |
Purchase_requisition_creator | text | N | |
Material | text | N | The requested material. |
Material_group | text | N | The categorization of the requested material. |
Purchase_requisition | text | N | A user-friendly name to identify the purchase requisition. |
Appproval_status | text | N | The status of the purchase requisition in the process. For example, ‘open’, ‘closed’, ‘pending’, ‘approved’, etc. |
Purchase_requisition_type | text | N | The categorization of purchase requisitions. |
Quantity | text | N | |
Requisitioner | text | N | The person who requested the purchase requisition. |
Value | double | N | A monetary value related to the purchase requisition. |
Purchase order
Purchase_orders_base_raw
The following table describes the fields of the Purchase_orders_base_raw table.
Purchase_order_ID | text | Y | The unique identifier of the purchase order. |
Company | text | N | The company for which the purchase order is created. |
Creation_date | date | N | The date on which the purchase order is created. |
One_time_supplier | boolean | N | An indicator if the supplier is a one time supplier. |
Purchase_order | text | N | A user-friendly name to identify the purchase order . |
Approval_status | text | N | The status of the purchase order in the process. For example, ‘open’, ‘closed’, ‘pending’, ‘approved’, etc. |
Purchase_order_creator | text | N | The person who created the purchase order. |
Purchase_order_type | text | N | The categorization of purchase orders. |
Purchasing_group | text | N | The purchasing group associated with the purchase order. |
Purchasing_organization | text | N | The purchasing organization associated with the purchase order. |
Supplier | text | N | The supplier associated with the purchase order. |
Supplier_country | text | N | The country associated to the supplier. |
Supplier_region | text | N | The region associated to the supplier. |
Purchase_order_items_base_raw
The following table describes the fields of the Purchase_order_items_base_raw table.
| Name | Type | Mandatory Y/N | Description |
Purchase_order_item_ID | text | Y | The unique identifier of the purchase order item |
Purchase_order_ID | text | N | The unique identifier of the purchase order |
Purchase_requisition_ID | text | N* | The unique identifier of the purchase requisition. |
Purchase_order_item_creator | text | N | |
Business_area | text | N | The business area associated with the purchase order item. |
Cost_center | text | N | The cost center associated with the purchase order item. |
Customer | text | N | The customer on behalf of whom the purchase order item is created. |
Customer_country | text | N | The country associated to the customer. |
Customer_region | text | N | The region associated to the customer. |
Delivery_complete | boolean | N | Indicator if all ordered goods are received. |
Latest_actual_delivery_date | date | N | The latest actual delivery date for the purchase order item. |
Latest_expected_delivery_date | date | N | The latest originally confirmed delivery date for the purchase order item. |
Material | text | N | The ordered materials. |
Material_group | text | N | The categorization of the ordered materials. |
Plant | text | N | The plant associated to the purchase order item. |
Purchase_order_item | text | N | A user-friendly name to identify the purchase order item. |
Storage_location | text | N | The storage location associated to the purchase order item. |
Quantity | text | N | The quantity and the unit of measurement ordered. |
Value | double | N | The monetary value related to the purchase order item. |
- If you want to include purchase requisition events in the process graphs, the
Purchase_requisition_IDfield is mandatory.
Goods_receipt_base_raw
The following table describes the fields of the Goods_receipt_base_raw table.
Goods_receipt_id | text | Y | The unique identifier of the goods receipt. |
Purchase_order_item_ID | text | N* | The unique identifier of the purchase order item. |
Company | text | N | |
Delivery_complete | boolean | N | |
Goods_receipt_creator | text | N | |
Material | text | N | |
Material_group | text | N | |
Plant | text | N | |
- If you want to include goods receipt events in the process graphs, the
Purchase_order_item_IDfield is mandatory.
Invoice
Invoices_base_raw
The following table describes the fields of the Invoices_base_raw table.
Invoice_ID | text | Y | The unique identifier of the invoice. |
Invoice_creator | text | N | |
Baseline_date | date | N | |
Discount_captured | double | N | |
Discount_percentage_1 | double | N | |
Discount_percentage_2 | double | N | |
Discount_period_1 | integer | N | |
Discount_period_2 | integer | N | |
Fiscal_year | text | N | |
Invoice_date | date | N | |
Invoice_type | text | N | |
Net_payment_period | integer | N | Net payment period of the invoice in days. |
Payment_method | text | N | |
Payment_terms | text | N | |
Posting_date | date | N |
- If you want to include accounts payable events in the process graphs, the
Invoice_IDfield is mandatory.
Invoice_items_base_raw
The following table describes the fields of the Invoice_items_base_raw table.
Invoice_item_ID | text | Y | The unique identifier of the invoice item. |
Invoice_ID | text | N* | The unique identifier of the invoice. |
Invoice_item_creator | text | N | |
- If you want to include events related to accounts payable in the process graphs, the
Invoice_IDandPurchase_ order_item_IDfields are mandatory.
Accounting
Accounting_documents_base_raw
The following table describes the fields of the Accounting_documents_base_raw table.
Accounting_document_ID | text | Y | The unique identifier of the accounting document. |
Invoice_ID | text | N* | The unique identifier of the invoice as known in the accounting system. |
Accounting_document_creator | text | N | |
Document_date | date | N | |
Document_type | text | N | |
Net_payment_period | integer | N | |
Payment_date | date | N | |
Payment_status | text | N | |
Posting_date | date | N | |
Transaction_type | text | N | |
- If you want to include events related to accounts payable in the process graphs, both the
Accounting_document_IDandInvoice_IDfields are mandatory.
Payment
Payments_base_raw
The following table describes the fields of the Payments_base_raw table.
Payment_ID | text | Y | The unique identifier of the payment. |
Accounting_document_ID | text | N* | The unique identifier of the accounting document. |
Payment_creator | text | N | |
Payment_is_complete | boolean | N | |
Payment_is_debit | boolean | N | |
- If you want to include payment events in the process graphs, the
Accounting_document_IDfield is mandatory.
Events
Events
The Events table contains all sub-event logs for all objects. The following table describes the fields of the Events table.
Activity | text | Y | The name of the event. This describes the step in the process. |
Event_end | datetime | Y | The timestamp associated with the end of executing the event |
Purchase_order_item_ID | text | Y | The unique identifier of the purchase order item. |
Goods_receipt_ID | text | Y | The unique identifier of the goods receipt. |
Activity_order | integer | N | The number that defines in which order activities are executed in case they have the same Event end. |
Automated | boolean | N | An indicator whether the event is manually executed or automated. |
Department | text | N | The department that executed the event. |
Event_detail | text | N | Information related to the event. |
User | text | N | The user who executed the event. |
User_function | text | N | The function associated with the user. |
User_type | text | N | The categorization of the user. |
Event_cost | double | N | The costs for executing the event. |
Event_start * | datetime | N | The timestamp associated with the start of executing the event |
Event_processing_time | integer | N | The time for executing the event (in milliseconds). |
- If both
Event_startandEvent_endare defined in your dataset, the duration of the event is known. This will be used to calculate the throughput time of events. If onlyEvent_endend is defined, the throughput time will be calculated as the difference between previousEvent_endand theEvent_end.Event_startis only taken into account if every record in the dataset contains a not-null value.noteIt is expected that for each record exactly one of the
IDfields is filled in, which is the one of the object on which the event takes place. The otherIDfields may be empty. Next to the standard mandatory fields (ActivityandEvent_end), oneObject_IDis mandatory. This field depends on the object the event is part of.
