Root cause analysis
What is root cause analysis?
When analyzing a business process, you may want to determine which field valuess are most associated with a certain outcome. This should help you to act on the root causes associated with the outcome. For example, in the Purchase-to-Pay process, you may want to analyze which field values have a high association with maverick buying.
With Root cause analysis, you can compare the influence of selected fields on a certain behavior to find significant data influencers for specific process situations. A set of reference objects is defined based on the Timeframe filter. This set is called Reference objects. Within this set of objects, you can select the behavior that you want to analyze by applying filters. For example, objects with a certain tag. This set is called the Selected objects. The influence of a field value is based on the number of occurrences in the selected objects.
For performance reasons, the counts of Reference objects and Selected objects are approximated. Although this may introduce a small margin of error, the reported numbers remain accurate enough to perform reliable root cause analysis.
Root cause analysis dashboard
Use the Root cause analysis dashboard to compare the influence of object fields on a set of selected objects within a reference set of objects.
Selecting the object used for Root cause analysis
If multiple objects are available for the data model of your process app, you can select a different object for analysis. This enables you to perform a root cause analysis from another point of view and to compare the influence of case properties related to a different object.
Follow this step to select a different object.
- Locate the Influence of selection on list, and select a different object from the list.
Performing a root cause analysis
Follow these steps to perform a root cause analysis.
| Step | Action |
| 1 | Use the Period filter to define the set of Reference objects. |
| 2 | Select Root cause analysis in the menu on the left of the dashboard. |
| 3 | Use the Filter panel to create filters that define the set of Selected objects, which are the objects you want to analyze the influence on. |
| 4 | Select the field you want to use for your analysis from the selector. |
Up to 1000 results are visible. When there is too much data, a warning icon is displayed.
Node limit slider
The Node limit slider enables you to reduce the complexity of the Root cause analysis tree, which increases the readability of the graph. By default, the detail of the Root Cause Analysis is automatically determined. You can use the Node limit slider to change the number of nodes shown.
Zoom in/zoom out
You can use the zoom in/zoom out buttons at the bottom to change the magnification of the Root cause analysis tree. The following table describes the buttons.
| Button | Click to... |
| Zoom in | |
| Zoom out | |
| Reset to the default view |
You can also use the mouse wheel to zoom in or zoom out.
Influence
Depending on the process, a process-specific name is displayed to identify Objects, for example, Purchase order items, or Incidents.
The Root cause analysis tree displays the value (%), the number of occurrences in the Selected objects, and the number of occurrences in the Reference objects for the field selected in the dashboard. A large deviation from the Reference objects indicates a possible high influence on the selection.
The percentage numbers in the nodes indicate the degree to which each attribute value influences a certain outcome, in comparison to the original baseline.
- The value (%) in the start node is the global baseline percentage. This is the initial state before any changes or influences are applied.
- The value (%) in the other nodes is the Influence (%) or impact. This represents how much deviation or change has occurred from the global baseline percentage due to the specific attribute value represented by that node. This enables you to identify which attribute values have the most significant impact and hence could be the potential root causes for a given problem or change.
Show significant influencers option
The Show significant influencers option enables you to zoom in by displaying the objects with a statistical significant influence. This should help you identify the objects that have the most impact on the selection. This statistical significance is computed from both the Influence (%) and the amount of objects a certain field has.
Adding layers
If desired, you can add more layers to the Root cause analysis.
In the above example, the combination of fields results in a set of Selected objects that has not enough (relevant) data to determine influencers. In this case, you can narrow down the set of Reference objects by adding a filter on the dashboard.
The following illustration shows the result.
When hovering over the fields in the tree, the Influence (%), the Reference objects, and the Selected objects are displayed.
The following table describes the metrics.
| Metric | Description |
| Influence (%) | The deviation of the Selected objects from the Reference objects. |
| Selected objects | The number of objects for the field in the total set of Selected objects. |
| Reference objects | The number of objects for the field in the total set of Reference objects. |
Example
Assume a total of 100 objects. A filter is applied to sort out objects that exceed a throughput time of 30 days. The filter results in 20 objects, equating to 20% of the total. This percentage is set as the "Reference %" or essentially, your baseline.
When aggregating, for instance, by Supplier, an influence percentage is displayed.
Consider Supplier X having a cumulative total of 30 objects, of which only five objects exceed a throughput time of more than 30 days. This means that 17% of the objects related to Supplier X have a long throughput time.
The influence percentage is computed based on the difference between the calculated % of objects exceeding the set throughput time (in the given example, 17%) and the Reference % (20%). In this scenario, the influence percentage equals -3% (17%-20%= -3%).
Next, consider Supplier Y has a total of 5 objects. 3 of these objects have a throughput time that exceeds 30 days (60%). In this scenario, the influence percentage of this would be 40% (60% - 20% = 40%).
