Skip to main content
Run the job
Follow these steps to run the extraction job.
  1. Select Jobs in the menu bar and locate the extraction job created.
  2. Select the Run Job icon from the pop-up menu.
  3. Wait until the job has finished. Depending on the amount of data, this can take several minutes.
  4. Once the extraction job has completed, the status "Transforming data" is displayed in the app overview the Process Mining portal.
    note
    You can monitor the progress in the log. Refer to Viewing logs.
Go to the Process Mining portal and check the Last succesful run date for the process app to see if the data load has completed successfully.
note
The date is only updated after all data has been processed. Depending on the amount of data, this might take several minutes up to an hour.
Scheduling jobs
If you want to run the extraction job on a regular interval, you can use the CData Sync Scheduler to define a schedule.
Follow these steps to schedule an extraction job.
StepAction
1Open the CData Sync extraction job created in Create a job.
2Go to the Schedule tab in the Settings panel.
Refer to the official CData Sync documentation for more information on how to schedule jobs.
