Skip to main content
Scheduling Data Runs
In production environments, typically data for process apps is refreshed at regular intervals. For example, every day, or every week. To make sure this happens, the extraction process can be scheduled which has to trigger the app to start data transformation and refresh the data in the Process Mining process app. Refer to Retrieving the SQL Server database parameters
In most cases Windows Task Scheduler is used to schedule the extraction script or process at regular intervals.
CData Sync Scheduler
If data extractions are done with CData Sync, you can use the CData Sync Scheduler to define a schedule to run the extraction job on a regular interval, check out Run the job - Scheduling jobs.
