Skip to main content
Accounting process
Accounting process provides an end-to-end view of the Purchase-to-Pay process from an accounting document process perspective. It enables you to track throughput times, revision trends, duplicate douments, and invoice capture efficiency across suppliers and channels. By combining accuracy, throughput time, and control metrics, the dashboard supports process improvement, data integrity, and compliance.
Accounting process overview
Check out KPIs for a detailed description of the KPIs related to the accounting document process.
Dashboard charts
The following table describes the dashboard charts of the Accounting process dashboard.
ChartDescription
Accounting milestonesDisplays throughput time metrics for suppliers, helping to monitor and compare process efficiency in accounting workflows across different suppliers.
Revision accounting document analysisDisplays the number of accounting documents and revisions per supplier, along with average throughput time from invoice creation to last revision, helping identify rework trends and monitor efficiency in accounting processes.
Revision events analysisDisplays the number and type of revision events across accounting documents and invoices, including average throughput times, helping assess revision frequency and process efficiency.
TrendDisplays the values of the selected metric over time, based on the accounting document Creation timestamp date.
Potential duplicatesDisplays accounting documents that may have duplicates, listing potential duplicate invoices or accounting records with exact or near matches to support data accuracy and prevent duplicate payments.
Invoice capture channelDisplays invoice processing performance by capture channel and supplier, showing the number of invoices, first-time-right rates, and average throughput times to support process improvement and decision-making on which channels to prioritize or improve.
note
You can select different metrics and fields to change the context.
