Skip to main content
Bar charts
Introduction
Bar charts can be used to group data and to compare certain metrics. The bars are displayed horizontally. The lengths of these bars are proportional to the values they represent. For each bar, the value is displayed. The total values for the metrics are displayed beneath the bar chart. The following illustration shows an example of a bar chart.
Bar chart example
Properties
You can edit the properties of a bar chart in the Edit bar chart panel.
The following table describes the properties of the Bar chart.
Element
Title
Text box that enables you to edit the title of the bar chart.
Tooltip
Text box that enables you add a text that will be displayed as tooltip when the user hovers the mouse over the chart title in the published process app.
Fields
List of fields available for the bar chart.
  • Use the Add field option to select one or more fields.
  • Enable the fields that are displayed on the bar chart by default.
  • Drag and drop the fields in the list to arrange the fields as desired.
Note:
You must at least select and enable one field for the bar chart. If you select multiple fields, the first field will be displayed by default.
Metrics
List of metrics to be available for the bar chart.
  • Use the Add metric option to select multiple metrics.
  • Enable the metrics that are displayed on the bar chart by default.
  • Drag and drop the metrics in the list to arrange the metrics as desired.
Note:
You must at least select and enable one metric for the bar chart. If you select multiple metrics, the first metric will be displayed by default.
