Configuring fields for Automation potential
Make sure the fields for Automation potential are correctly mapped in the Event table in the data model:
Automated -
Event_cost -
Event_processing_time
Event_cost and Event_processing_time
Event_cost and Event_processing_time used to calculate Automation potential are not part of the input data. You can configure these fields for the event log in Data transformations using SQL statements.
The following code block shows an example SQL query to define Event_cost.
case
when tableA."Activity" = 'ActivityA'
then {{ pm_utils.to_double(20.00) }}
when tableA."Activity" = 'ActivityB'
then {{ pm_utils.to_double(10.00) }}
when tableA."Activity" = 'ActivityC'
then {{ pm_utils.to_double(5.00) }}
when tableA."Activity" = 'ActivityD'
then {{ pm_utils.to_double(0) }}
end as "Event_cost"
The following code block shows an example SQL query to define Event_processing_time.
case
then 50000
then 120000
then 300000
then 40000
end as "Event_processing_time"
The time unit of Event_processing_time is milliseconds.
Providing data input using dbt seeds
For process apps that still contain the Automation_estimates_raw.csv seeds file in the seeds\ folder of the data transformations, you can use this file to provide input data to be used for the calculations in the Automation potential dashboard. For all activities, you can provide the Event_processing_time (in milliseconds) and the Event_cost. The following illustration showns an example.
If the event_processing_time is provided using the Automation_estimates_raw.csv seeds file, but not filled in for all activities, the Manual processing time for the remaining activities is NULL by default. Consider using the average throughput time as the event_processing_time for these activities.
If you are using an app template where you provide an event_log as input, you can also specify the event_processing_time as a column in that file. Values specified on event level will take precedence over values specified per activity using the seed file.
