Configuring Tags
If you want to use the Tags dashboard to analyze tags in your process, tags must be defined for your app template.
For certain app templates, there are out of the box tags available, which will be shown in the dashboard. In the documentation for your specific app template you will find an overview of the available tags. The App Templates page contains links to the documentation for all available app templates.
All custom process app templates have one tag implemented out of the box that checks whether a case has rework activities that are executed by different users.
If no data is available in the Tags dashboard, you need to configure your own tags using data transformations. Here you can also configure any default tags to your business needs. The following table describes the tags configuration files for the different app templates.
| Process apps based on app template | Tags configuration file |
| Event log | models\3_business_logic\Tags_base.sql |
| Custom process 1 | models\3_business_logic\Tags_base.sql |
| Purchase-to-Pay | models\3_business_logic\Tags.sql |
| Purchase-to-Pay SAP | models\3_business_logic\Tags_purchase_order_items.sql models\3_business_logic\Tags_accounting_documents.sql |
| Order-to-Cash | models\3_business_logic\Tags.sql |
- This applies to the Custom process app template and all other app templates based on Custom process, for example Warehouse-Management SAP.
For Custom process you can also upload tags using the Tags.csv file. Check out Custom process input fields.
Adding business logic in transformations
In the last transformation step, business logic is added as needed for data analysis.
Each record in the tags table represents one tag for a certain case. Example tags are:
- SLA violation for a contract.
- a payment done by an unauthorized person.
The mandatory fields for this table are the Case_ID, and Tag.
Not all objects will have a tag and some objects may have multiple tags.
Refer to Data transformations editor for more information.
Providing tag configuration input in Data transformations
You can provide additional input data to be used for the tags in the Tags dashboard using SQL statements in Data transformations. For all tags, you can configure the following fields.
| Name | Type | Description |
Tag | Text | The name of the tag. |
Tag_type | Text | The tag type. |
Case_ID | Text/Integer | The ID of the Case to which the tag is related. |
SQL examples for configuring Tags
This page contains some SQL examples that you can use to configure Tags using transformations.
The SQL examples are based on Event log app templates, and use Cases that have a Case_ID. If you want to use the SQL examples to define Tags for Purchase-to-Pay app templates or Order-to-Cash app templates, make sure to use the appropriate object and the related internal object_ID. When extending the implementation for Tags, follow the existing implementation.
The following code block shows an example SQL query to define a tag.
select
Time_to_resolved."Case_ID",
{{ pm_utils.as_varchar('Resolved in less than a day') }} as "Tag",
{{ pm_utils.to_varchar('Optional tag type') }} as "Tag_type"
from Time_to_resolved
where Time_to_resolved."Throughput_time" < 24
The following code block shows an example Common Table Expression (CTE) SQL query to configure a tag.
Time_to_resolved as (
select
Event_log."Case_ID",
{{ pm_utils.datediff('hour', 'min(Cases."Creation_date")', 'max(Event_log."Event_end")') }} as "Throughput_time"
from {{ ref('Event_log') }} as Event_log
left join {{ ref('Cases ') }} as Cases
on Event_log."Case_ID" = Cases."Case_ID"
where Event_log."Activity" = 'Set resolution to Done'
group by Event_log."Case_ID"
Directly follows
This SQL code identifies cases where activity 'X' is directly followed by activity 'Y' and tags them as "Violation".
with Event_log_base as (
select * from {{ ref('Event_log_base') }}
-- Event log with current activity and next activity
Event_log_extended as (
select
Event_log_base."Case_ID",
Event_log_base."Activity" as "Current_activity",
lead(Event_log_base."Activity") over (order by "Event_end") as "Next_activity"
from Event_log_base
-- This SQL code checks whether activity X is directly followed by Y in a given case
Directly_follows as (
select
Event_log_extended ."Case_ID",
{{ pm_utils.as_varchar('Activity X directly followed by activity Y') }} as "Tag",
{{ pm_utils.as_varchar('Violation') }} as "Tag_type"
from Event_log_extended
where Event_log_extended ."Current_activity" = 'X' and Event_log_extended ."Next_activity" = 'Y'
group by Event_log_extended ."Case_ID"
select * from Directly_follows
Indirectly follows
This SQL code identifies cases where activity 'X' is directly or indirectly followed by activity 'Y' and tags them as "Violation".
Cases_with_activity_X as (
select
min(Event_log_base."Event_end") as "Event_end"
from Event_log_base
where Event_log_base."Activity" = 'X'
group by Event_log_base."Case_ID"
-- Activity X is directly or indirectly followed by activity Y
Indirectly_follows as (
select
{{ pm_utils.as_varchar('Activity X indirectly followed by activity Y') }} as "Tag",
from Event_log_base
inner join Cases_with_activity_X
on Event_log_base."Case_ID" = Cases_with_activity_X."Case_ID"
where Event_log_base."Activity" = 'Y' and Event_log_base."Event_end" > Cases_with_activity_X."Event_end"
select * from Indirectly_follows
Activity X multiple times
This SQL code identifies cases where activity 'X' occurs more than once, and tags them as "Inefficiency".
-- This SQL code checks if Activity X occurs twice or more times in the same case
Activity_X_multiple_times as (
select
{{ pm_utils.as_varchar('Activity X multiple times') }} as "Tag",
{{ pm_utils.as_varchar('Inefficiency') }} as "Tag_type"
from Event_log_base
having count(Event_log_base."Activity") > 1
select * from Activity_X_multiple_times
Case has activity X
This SQL code identifies cases that have one or more activities with a name that contains 'X', and tags them as "Inefficiency".
-- Case has activity with name like X
Case_has_activity_X as (
select
{{ pm_utils.as_varchar('Case has activity X') }} as "Tag",
from Event_log_base
where {{ pm_utils.charindex('X', 'Event_log_base."Activity"') }} > 0
select * from Case_has_activity_X
Case has no activity X
This SQL code identifies cases for which there are no activities that have a name containing 'X' and tags them as "Inefficiency".
Cases as (
select * from {{ ref('Cases') }}
-- Case has no activity with name like X
-- Obtained by subtracting the set of cases that have activity X from the set of all cases
Case_has_no_activity_X as (
select
Cases."Case_ID",
{{ pm_utils.as_varchar('Case has no activity X') }} as "Tag",
from Cases
where Cases."Case_ID" not in (
select
from Event_log_base
select * from Case_has_no_activity_X
Starts with
This SQL code identifies cases that start with activity 'X' and tags them as "Violation".
-- Add row_number to initial event log
Event_log_base_numbered as (
select
Event_log_base."Activity",
Event_log_base."Event_end",
row_number() over (partition by Event_log_base."Case_ID" order by Event_log_base."Event_end") as "Row_number"
from Event_log_base
-- Case starts with activity X
Starts_with as (
select
Event_log_base_numbered."Case_ID",
{{ pm_utils.as_varchar('Case starts with activity X') }} as "Tag",
from Event_log_base_numbered
where
Event_log_base_numbered."Row_number" = 1
and Event_log_base_numbered."Activity" = 'X'
select * from Starts_with
Throughput time longer than 10 days
This SQL code identifies cases for which the throughput time is longer than 10 days and tags them as "Inefficiency".
-- Throuput time of each case
Throughput_time_per_case as (
select
{{ pm_utils.datediff('day', 'coalesce(min(Event_log_base."Event_start"), min(Event_log_base."Event_end"))', 'max(Event_log_base."Event_end")') }} as "Throughput_time"
from Event_log_base
-- Case throughput time is longer than 10 days
Throughput_time_longer_than_10_days as (
select
Throughput_time_per_case."Case_ID",
{{ pm_utils.as_varchar('Throughput time is longer than 10 days') }} as "Tag",
{{ pm_utils.as_varchar('Inneficiency') }} as "Tag_type"
from Throughput_time_per_case
where Throughput_time_per_case."Throughput_time" > 10
select * from Throughput_time_longer_than_10_days
Duration more than 30 minutes
This SQL code identifies cases where the time duration between activity 'X' and 'Y' is more than 30 minutes and tags them as "Inefficiency".
-- First activity X of each case
First_activity_X_of_each_case as (
select
from Event_log_base
-- Last activity Y of each case
Last_activity_Y_of_each_case as (
select
max(Event_log_base."Event_end") as "Event_end"
from Event_log_base
-- Time between first X and last Y > 30 minutes
Duration_more_than_30_minutes as (
select
First_activity_X_of_each_case."Case_ID",
{{ pm_utils.as_varchar('Duration more than 30 minutes') }} as "Tag",
from First_activity_X_of_each_case
inner join Last_activity_Y_of_each_case
on First_activity_X_of_each_case."Case_ID" = Last_activity_Y_of_each_case."Case_ID"
where {{ pm_utils.datediff('minute', 'First_activity_X_of_each_case."Event_end"', 'Last_activity_Y_of_each_case."Event_end"') }} > 30
select * from Duration_more_than_30_minutes
