Dashboards
Introduction
In the dashboard editor you can edit the properties of a dashboard.
Follow these steps to edit the dashboard properties.
- Open the dashboard editor. Check out Working with the dashboard editor.
- In the menu on the left, select the dashboard for which you want to edit the properties.
- Select the dashboard title at the top, to display the Edit dashboard panel.
Dashboard properties
You can edit the properties of a dashboard in the Edit dashboard panel. The following table describes the dashboard properties.
| Property |
Description |
| Dashboard name |
Text box that enables you to edit the title of the dashboard. Tip: You can also change the dashboard name in the menu on the left. Select the dashboard you want to rename and select the Edit icon |
| Tooltip |
Text box that enables you to add a text that will be displayed as tooltip when the user hovers the mouse over the dashboard title in the published process app. |
| KPIs |
List of KPIs to be displayed in the KPI bar. Use the Add KPI option to select multiple KPIs up to the maximum number of 6 KPIs. Tip:You can drag and drop the KPIs in the list to arrange the KPIs as desired. |
| Filters |
Filter panel that enables to you to filter data from the tables before it is provided to the dashboard. |
Adding dashboard level filters
Dashboard filters enable you to filter data from the tables before it is provided to the dashboard. With dashboard filters, you can create a subset of the data to create more specific visualizations that can be used by business users. When business users open a dashboard that contains dashboard filters, the dashboard will display data according to the filters.
When one or more filters are defined for a dashboard, the Dashboard filters icon
is displayed next to the dashboard name. Business users can select the icon, to view the applied dashboard filters.
Business users can still add global filters, which are applied on top of the dashboard level filters. But they cannot change the dashboard level filters.
Adding a dashboard filter
Follow these steps to add a dashboard filter.
| Step | Action |
| 1 | Select the dashboard for which you want to add a dashboard level filter. |
| 2 | Select Add filter in the dashboard properties panel. |
| 3 | Select the filter from the list of filters or search for the filter you want to add. |
After you define a filter for a dashboard, the
icon is displayed in the dashboard header.
Dashboard filters are similar to global filters. Check out Filters for a detailed description of available filters, process filters, and filter types.
Sections
Adding a section
Follow these steps to add a new section to the app menu.
- Select
next to the process app name. - Select Add section from the context menu. A new section labeled Section name is added to the menu.
You can add dashboards to the section, either by dragging and dropping existing dashboards or Creating dashboards.
Renaming a section
Follow these steps to rename a section from the app menu.
- In the menu on the left, select the section and select the Rename section icon
. - Enter a name for the new section, and select the Save icon
Deleting a section
Follow this step to remove a section from the app menu.
In the menu on the left, select the section and select the Remove section icon
The section is removed from the menu without a notification message.
Arranging dashboards and sections
You can arrange the dashboards and sections to change the layout of the process app by dragging and dropping the dashboards or sections in the dashboards panel on the left.
When you rearrange a section, all the dashboards of the section will be moved as well.
Arranging charts on a dashboard
You can rearrange the layout of the dashboard by dragging and dropping charts. To do this, drag a chart and drop it on top of another chart. The chart that was originally in that position will move to the open position of the dragged chart, which results in swapping their places on the dashboard.
Copying and pasting charts
You can easily copy a chart and paste it in a different location within the same dashboard or across dashboards. Copying and pasting a chart allows you to reuse your charts and make modifications without having to create entirely new ones.
When pasted, the chart retains its original configuration so you can quickly adjust only what is needed for the new context. Any dashboard-specific settings can be modified independently after pasting.
Follow these steps to copy and paste a chart.
| Steps | Action |
| 1 | Right-click on the chart you want to re-use to open the context menu. |
| 2 | Select Copy. |
| 3 | Navigate to the dashboard on which you want to insert the chart and right-click to open the context menu. |
| 4 | Select Paste from the menu. The copied chart is inserted. |
You can also use the CTRL+C and CTRL+V keyboard shortcuts to copy and paste charts.
Removing charts
Follow these steps to remove a chart from the dashboard.
- Select the dashboard for which you want to delete a chart.
- Open the context menu for the chart you want to delete and select Cut.
The chart is removed, and an empty tile is displayed on the dashboard.
You can also select the Remove chart icon
in the properties panel at the right.
Adding a chart
You can create a new chart from an empty tile. Follow these steps to add a chart to a dashboard.
- Click on the empty tile to select it.
- Select the type of chart you want to add in the chart list at the right.
- Define the properties for the new chart. Check out Charts.
Editing charts and process graphs
Similar to the dashboard properties you can edit the properties of charts and process graphs.
Check out Charts.
Check out Process graphs.
