Skip to main content
Duplicating metrics and fields
Duplicating allows you to re-use a metric or calculated field and make modifications without the need to create a complete new metric or field.
Duplicating a metric or field creates a copy of the original directly underneath the duplicated metric or field.
Follow these steps to duplicate of a metric or field.
  1. In the Data Manager panel, locate the metric or field you want to duplicate.
  2. Open the actions menu and select Duplicate metric, or Duplicate field.
