KPI values lists
Introduction
A KPI values list can be used to create a dashboard with a representation of the main KPIs of the process that gives insight into the overall process performance. The following illustration shows an example of a KPI values list.
Properties
You can edit the properties of a bar chart in the Edit KPI value list panel.
You can select different metrics for which you want to display a KPI charts.
The following table describes the properties of the KPI value list.
| Element | Description |
| Tooltip | Text box that enables you add a text that will be displayed as tooltip when the user hovers the mouse over the chart title in the published process app. |
| KPIs | List of metrics to be displayed in the KPI list. Use the Add KPI option to select one or more metrics. Tip: You can drag and drop the metrics in the list to arrange the KPI charts in the desired order. |
Defining the KPIs
The following table describes the properties for the KPI.
| Format X-axis | List box that enables you to select the field displayed on the chart. The Format X-axis is a mandatory property. Note: You can select the new Timeframe filter as a field for the x-axis of a line chart or a KPI chart. When a business user selects a different timeframe the chart will change accordingly. |
| Link to dashboard | Drop-down list that enables you to select the dashboard that should be opened when the user selects View details . If you do not select a related dashboard, the View details button is disabled. |
| Thresholds | Enables you to view the thresholds defined for the metric on the KPI chart displayed in the KPI values list. |
