Skip to main content
Managing access for process apps
note
To manage permissions for individual process apps, you must have Manage access permission for the particular process apps. When you have created a process app, you will automatically be granted Manage access permissions for the app.
Introduction
In Process Mining you can grant access to process apps for users and groups. Based on the permissions, users who are granted access can edit, view, or delete process apps, or manage access for process apps.
note
By default, users who belong to a group inherit the access permissions as defined for the group. When editing the permissions for the user, you cannot lower the permissions for the user.
The following table describes the different permissions that can be set for users or groups.
Permission
Manage access
The user, or users in the group, can manage access for the app.
Edit data
The user, or users in the group can upload data for development and production. Furthermore, they can perform all available actions in Data transformations , such as add and remove tables, edit transformations, edit the data model, and start data runs.
Note:
Users with Edit data permission also have Edit dashboards and View permissions.
Edit dashboards
The user, or users in the group, can edit the app settings, edit the dashboards, import a BPMN model, and publish the app.
Note:
Users with only Edit dashboard permission cannot upload data in their apps, unless they explicitly get the Edit data permission.
View
The user, or users in the group, can view the app.
Delete
The user, or users in the group, can delete the app.
note
Edit permission includes View permission. When you assign Edit permission to a user or a group of users, the View permission is selected automatically for these user or users. Similarly, when you remove the View permission, the Edit permission is removed automatically.
Editing app permissions
note
When defining app permissions for users, make sure that the licenses that are needed to perform the role are available. Select the Process app menu icon and select Manage permisssions to open the App permissions. The App permissions page is displayed, showing the app permissions for all groups and users. The Manage permission option is only enabled for apps for which you have Manage access permission.
Follow these steps to edit permissions for a process app.
  1. Locate the group or user for which you want to edit the permissions and select Edit.
  2. Select the appropriate app permissions for the group or user and select Save.
    note
  3. Select the fields from the Field access list to grant access to the restricted fields for the user or group you are defining the permissions. Check out Setting data restrictions for a process app.
  4. Select the record access policies from the Apply record policy list to restrict access to the data defined by the selected policies for the user or group. Check out Setting data restrictions for a process app.
  5. Select Save.
Adding permissions for a user or group
Follow these steps to assign roles to a user or group that is not listed.
  1. Select +Add a user or group to open the Assign roles panel.
  2. In the Add Users and Groups field start entering the email address of the user, or the name of the group, you want to grant permissions for the process app.
  3. If you want to add more users or groups, repeat step 2 to add the users and/or roles.
  4. Select the App access permissions you want to grant to the users and/or groups listed in the Add Users and Groups field.
  5. Select Save.
New users and/or groups are listed on the App permissions page. For each user or group the assigned permissions are displayed.
note
Users who are member of multiple groups, can get assigned multiple filters based on the selected record access policies for the different groups. The combined set of filters will be available for the user.
Revoking permissions for a user or group
When you remove a user or group, the individual user, or the users that are part of the group do not have access to process app anymore.
Follow these steps to remove a user or group.
  1. Locate the user or group you want to remove from the User and group access list, and select the Delete icon Delete icon. A confirmation message is displayed.
A confirmation message is displayed. 2. Select Confirm to remove the selected user or group.
