Maverick buying
Maverick buying is the dashboard where you can analyze your process regarding maverick buying. It enables you to analyze purchase order items labeled with one or more maverick buying tag.
Maverick buying overview
Check out KPIs for a detailed description of the KPIs related to maverick buying.
Dashboard charts
The following table describes the dashboard charts of the Maverick buying dashboard.
| Chart | Description |
| Conditions | Displays supplier performance and activity metrics for the end-to-end process, helping evaluate supplier efficiency, reliability, and impact on overall process performance. |
| Analyis | Provides information on how much buying activity happens outside the approved Purchase-to-Pay process, and enables you analyze the extent of non-compliant purchasing activity by supplier, measured through the Maverick PO items rate. |
| Trends | The graph on the Trend chart shows the values of the selected metric over time, based on the Purchase order item process start date. |
| End to end process | The process graph displays the end to end process for purchase order items regarding maverick buying. |
note
You can select different metrics and fields to change the context.
