Table charts
Introduction
Table charts can be used to display values of different fields related to an object as a table with rows and columns. The following illustration shows an example of a table chart.
For a table chart, you select the columns you want to display.
Properties
You can edit the properties of a table chart in the Edit table chart panel.
The following table describes the properties of the Table chart.
| Element |
Description |
| Title |
Text box that enables you to edit the title of the table chart. |
| Tooltip |
Text box that enables you add a text that will be displayed as tooltip when the user hovers the mouse over the chart title in the published process app. |
| Columns |
List of columns to be available for the table chart.
Note: You must at least select one column for the table chart. If you select multiple columns, the first column will be displayed by default. |
