Tags overview
The Tags overview dashboard enables you to analyze the tags that occur in the process. Tags identify specific issues or characteristics found during process analysis, such as matching errors or duplications. You can use the Tags overview dashboard to identify common data quality or matching problems in your process.
If you want to use the Tags overview dashboard to analyze tags, the tags must be present in your dataset.
Check out Configuring Tags for more information.
Purchasing process
The Tags – Purchase order items chart lists the tags assigned to purchase order items, grouped by tag type. For each tag, the type of issue and and the number purchase order items are displayed.
Accounting process
The Tags – Accounting document chart lists the tags assigned to accounting documents, grouped by tag type. For each tag, the type of issue and and the number accounting documents are displayed.
