Skip to main content
Using LLM functions in data transformations
note
Check out the official Snowflake documentation on Snowflake AI and ML for an overview of Snowflake's artificial intelligence and machine learning capabilities. Only the explicit data passed in function calls is sent to the LLM.
  1. Data does not leave the Snowflake environment.
  2. Data is not retained beyond processing and is not used for training.
  3. Snowflake contracts and architecture are designed to meet enterprise data governance standards.
Introduction
LLM functions enable you to process unstructured text into categorical output for aggregated analysis in your dashboards. Using LLM functions eliminates the need for complex regex in SQL, making it easier to configure and adapt your transformations based on new data.
Refer to the official Snowflake documentation on Cortex AISQL (including LLM functions) for more information about using LLM functions.
warning
Using LLM functions in your SQL can significantly impact transformation time. For example, applying a classification function to 1 million records can increase the processing time by at least half an hour.
Example use cases of LLM functions in data transformations are:
  • AI_CLASSIFY function for classification of data. Refer to the official Snowflake documentation on AI_CLASSIFY for more information.
  • ENTITY_SENTIMENT function for sentiment analysis. Refer to the official Snowflake documentation on ENTITY_SENTIMENT for more information.
    note
    In the unlikely event that you exceed your fair use limits for LLM usage, UiPath® does not impose any immediate restrictions, so customer operations can continue uninterrupted. Any changes to this or the commercial offering will be communicated in advance, to provide a smooth and seamless experience.
Classification
This section describes how to use the AI_CLASSIFY function in a process mining context, including examples.
Example: analysis of high-level process
Processes can consist of many different activities, some of which may be very similar and can be mapped to higher-level categories. This type of mapping reduces the number of process variants and enables analysis at a more abstract level.
For example, in a Purchase-to-Pay process, approval events can occur at different levels, such as “Approve purchase requisition”, “Approve order level 1”, “Manager approval”, etc. Each of these activities can be mapped to a generic “Approve” activity.
Another example is “Change” events, such as “Change price”, “Change delivery date”, or “Change supplier”. Mapping these to a single “Change” activity reduces the number of paths in the process and simplifies the process graph view.
The following code block shows a SQL example on how to apply the AI_CLASSIFY function for defining the high-level process.
select
{{ pm_utils.id() }} as "Event_ID",
Purchase_order_item_event_log."Purchase_order_item_ID",
Purchase_order_item_event_log."Event_end",
coalesce(
to_varchar(
AI_CLASSIFY(
Purchase_order_item_event_log."Activity",
['Create', 'Change', 'Approve', 'Complete', 'Cancel']):labels[0]),
'Not mapped') as "High_level_activity"
from {{ ref('Purchase_order_item_event_log') }} as Purchase_order_item_event_log
As the first argument of this function, provide the original Activity column from your events table. The second argument should be a list of high-level activities to which the activities will be mapped. In this example the activities are mapped to “Create”, “Change”, “Approve”, “Complete”, or “Cancel”.
Steps to implement the high-level process analysis:
  1. Create a separate SQL file in your project, for example High_level_events.sql, and add the high-level process SQL logic to it.
  2. Add the High_level_events to the data model and configure the relation. In this example, the high level events are connected to the purchase order items table based on the Purchase_order_item_ID.
  3. Add an additional process with the purchase order items as main object and the high-level events as the events for this process.
  4. When applying your changes to dashboards, you can create the process graph and other dashboards based on the high-level process.
The following illustration shows an example.
Example high-level process analysis result
note
  • The AI_CLASSIFY function returns values in the format { “labels”: [“Create”] }. The :labels retrieves the value ”Create” and the to_varchar() function removes the surrounding quotes.
  • When none of the categories seems to be a good match, the value that is generated by the AI_CLASSIFY function remains null. To prevent these records from being excluded from the dataset, map the null values to a constant (e.g., "Unmapped") to indicate that these activities were not classified.
Example: classify customer request types
Customer requests are a typical example of unstructured data. Each type of request requires a different next action. To analyze the different request types more effectively in dashboards, you can categorize them using LLMs—without the need for manual user intervention.
The following code block shows a SQL example on how requests can be categorized in “Feedback”, “Question”, or “Complaint”.
select
Requests_input."Request_ID",
Requests_input."Request",
to_varchar(
AI_CLASSIFY(
['Feedback', 'Question', 'Complain']):labels[0])
as "Request_classified"
from {{ ref('Requests_input') }} as Requests_input
tip
Classifying values for each record can impact ingestion performance. To optimize processing time, consider filtering the tables on which you apply the AI_CLASSIFY function to only include the records relevant for your analysis.
You can add the classified request types to the app and dashboards to enable more aggregated analysis. This provides greater insight compared to using the original request text directly, which is often unique for each record and can lead to a large number of distinct values.
The following illustration shows an example of classification.
docs image
Sentiment analysis
This section describes how to use the ENTITY_SENTIMENT and SENTIMENT functions in a process mining context, including examples.
You can apply sentiment analysis to unstructured text to classify whether the content is positive or negative. This type of analysis can be used, for example, to:
  • Analyze feedback to improve products or services.
  • Track sentiment trends over time for decision-making.
There are two type of sentiment analysis functions available.
  • Use the ENTITY_SENTIMENT function for categorical results (e.g., “Positive”, “Negative”, “Neutral”, “Mixed”, or “Unknown”). By default, the input is analyzed for the overall sentiment of the text. The output is returned in the following format:
    "categories": [
    "name": "overall",
    "sentiment": "positive"
  • Use the SENTIMENT function for numeric results (e.g., a sentiment score on a scale). The SENTIMENT function returns a value between -1 and 1, indicating the degree of negativity or positivity in the input text. You can use these numeric sentiment values in dashboard metrics to analyze sentiment across different levels of aggregation.
Example: sentiment analysis user feedback
The following code block shows a SQL example on using sentiment analysis for user feedback.
select
Feedback_input."Feedback_ID",
Feedback_input."Feedback",
to_varchar(
SNOWFLAKE.CORTEX.ENTITY_SENTIMENT(
Feedback_input."Feedback"):categories[0]:sentiment)
as "Sentiment_category",
SNOWFLAKE.CORTEX.SENTIMENT(
as "Sentiment_value"
from {{ ref('Feedback_input') }} as Feedback_input
By default, only the overall sentiment is determined. If you want to specify specific topics on which you want to get the sentiment, for example “Price” or “Support”, you can add the categories as a second argument to the ENTITY_SENTIMENT function. The output will be a sentiment value for each of the specified category.
To extract the correct values, you must adjust the SQL logic. Instead of referencing category[0] (which only selects the first category), modify the query to select the sentiment values for the specific categories of interest.
The following illustration shows example results of user feedback sentiment analysis.
Example results of user feedback sentiment analysis
