Skip to main content
Distribution charts
Introduction
Distribution charts can be used to show the distribution of values of a numerical field. The bars are displayed vertically. The following illustration shows an example of a distribution chart.
Distribution chart example.
In a distribution chart, you select the field for which you want to display values on the X-axis. The Y-axis is used to display the variable values defined by a metric. By default, the metric displayed on the Y-axis is the record count. If you want to display a different value, you can choose a different metric.
Properties
You can edit the properties of a distribution chart in the Edit distribution chart panel.
The following table describes the properties of the Distribution chart.
PropertyDescription
TitleText box that enables you to edit the title of the distribution chart.
TooltipText box that enables you add a text that will be displayed as tooltip when the user hovers the mouse over the chart title in the published process app.
FieldCombo box that enables you to select the field that defines the values displayed on X-axis.
MetricCombo box that enables you to select the metric that defines the values displayed on Y-axis.
