Viewing logs
For every data run, a log is created with information about the extraction, loading, and transformation of the data. You can select the View log option to find out more details on the latest data run for your process apps.
Refreshing the log file
You can view the log file for a data run in progress. In this case, you can select the
icon to refresh the log file and to reload the current status of the logs. This enables you to monitor the progress of the data run.
Opening data transformations
You can use the Data transformations link to directly go to Data transformations to debug any errors that appear in the log.
No logs available
When starting a data run, the log file is empty. After about 10 seconds the first log messages will be available.
It can happen that there are no log files available after a failed data run. For example, when you have accidentally started a new data run that failed because the previous data run was not finished. In this case, you should not start a new data run, and wait for the first run to be completed. When the run is finished, the log messages of the first run will show, and the corresponding run status (run failed/success) is displayed.
Log levels
The log contains different log levels to indicate the severity of the message:
| Log level | Description | Data run status |
| Information | An Information message contains helpful information on the progress of the datarun. | Success |
| Warning | A Warning refers to a potential problem in your data that might affect what will be displayed on a chart in the published process app. It is advised to resolve any warnings to prevent any potential future problems. | Success |
| Error | An Error refers to a mistake in your data that prevents the process app from loading the data or running the transformations. You must resolve all errors to enable a successful data run. | Failed |
Filtering logs
By default, Errors, Warnings, and Information messages are displayed when you open the Log. You can use the Filter menu to change the log level. The following illustration shows an example.
Saving the log file
You can select the
icon to copy the contents of the log file and paste in, for example, a Notepad file that you can save on your computer. This enables you to view the messages when working on solving the issues causing errors or warnings.
This also enables you to share the contents of the log file, for example if you need support.
