Skip to main content
2023.10.4
Addendum: December 18, 2024
Configuring process app security
There was an issue where editing Data transformations did not work when the process app security was configured as single_account. This issue has now been resolved.
Check out Configuring process app security in the Automation Suite guide for more information.
Release date: June 27, 2024
Disabling use of pre-signed URLs
If you use Amazon S3 storage objects and you want to prevent uploading data using a pre-signed URL, this is now handled via the global disable_presigned_url flag.
Refer to Pre-signed URL configuration in the Automation Suite guide for more information.
Loading data using CData Sync
We now support CData Sync 2024 - 24.1.8885 for Loading data using CData Sync.
We are constantly working to improve your UiPath® Process Mining experience. Even though there are no major significant changes with this release, we made sure to bring security and accessibility improvements as well as minor bug fixes to our product.
