Adding fields
You can add new fields using Data transformations. Any additional field that is added to the SQL transformations of the output tables will show up in the app.
Prerequisites
- Make sure the inout data needed for your new field is available in your app. See Loading data.
- Make sure your data model adheres the requirements. See Data model requirements.
- Make sure the new field is defined in table SQL file in the models -> 1_input section of the Transformations for which you want to add a field. See also Adding new input tables.
Creating a new output field
Follow these steps to create a new output field using Data transformations.
Go to the Data transformations editor.
Select the applicable output table SQL file of the Transformations for which you want to define an output field.
Add the field in the
selectstatement.
Select Apply to dashboards and run the transformations to make the field available for use in dashboards.
noteThis may take several minutes. Only if the run finishes successfully, the new field will show up in the Data Manager.
Select Edit dashboards and open the Data Manager.
A message is displayed to inform you that new fields have been added. Select Confirm to continue.
Locate the new field and check the Source field and the Type for the new field.
The new field is marked with a blue dot.
The new field is now available for use in dashboard charts.
Once the process app is published with the new field, the blue dot is no longer displayed.
