Skip to main content
Downloading DataBridgeAgent
Use the following link to download DataBridgeAgent: https://download.uipath.com/ProcessMining/versions/21.10.4/DataBridgeAgent/DataBridgeAgent-21.10.4.zip
note
You can only use .mvp connectors of a Process Mining on-premises standalone version that is the same version as the DataBridgeAgent. (v2021.10.4).
DataBridgeAgent is a standalone tool. It is recommended to create a separate folder on the server to use DataBridgeAgent.
note
Make sure to install DataBridgeAgent in a folder on the C:\ drive. Since DataBridgeAgent contains connectors that have rather long names, file paths can become very large, which may cause issues when running the datarun.bat file to create the dataset. Do not install DataBridgeAgent in the in the Process Mining installation folder (PLATFORMDIR). Also, do not install DataBridgeAgent in the Downloads folder.
