Skip to main content
KPI trends lists
Introduction
KPI trend lists can be used to create a dashboard with a graphical representation of the main KPIs of the process that gives insight into the overall process performance. The following illustration shows an example of a KPI trends list.
KPI list example
The View details button on a KPI trends list enables the user to go to the related dashboard for further analysis.
Properties
You can edit the properties of a bar chart in the Edit kpi list panel.
You can select different metrics for which you want to display a KPI charts. For each KPI chart you must select the field that is displayed on the X-axis. Furthermore, you can select the dashboard to which the View details button should be linked.
Below is a description of the properties of the Kpi list.
Element
Tooltip
Text box that enables you add a text that will be displayed as tooltip when the user hovers the mouse over the chart title in the published process app.
Metrics
List box that enables you to select the metrics for which you want to display a KPI chart.
You can select multiple metrics.
Select KPI chart
Drop-down list that enables you to select the KPI chart for which you want to define the properties.
Format X-axis
List box that enables you to select the field displayed on the chart.
The Format X-axis is a mandatory property.
Note:
You can select the new Timeframe filter as a field for the x-axis of a line chart or a KPI chart. When a business user selects a different timeframe the chart will change accordingly.
Link to dashboard
Drop-down list that enables you to select the dashboard that should be opened when the user clicks on View details .
If you do not select a related dashboard, the View details button is disabled.
