Analysis - End to end process
Introduction
Analysis - End to end process is the main dashboard where you can analyze the complete Purchase-to-Pay process regarding purchase order items.
KPIs
The following table describes the KPIs that are displayed at the top of the Analysis - End to end dashboard.
| KPI | Description |
| Automation rate | The percentage of automated events in the Purchase-to-Pay process from end-to-end. |
| Variants | The number of various process paths different purchase order items have taken from end-to-end. A variant is a specific path through the process, a set of activities that were taken in a specific order. Usually, several purchase order items have followed the same variant. |
| Avg. throughput time end to end | The average throughput time for the end-to-end process, from creating a purchase requisition to the actual payment for the related invoice. |
| Total item value | The total value of the purchase order items created during the selected period. |
| Number of items | The total number of purchase order items created during the selected period. |
| Purchase orders | The total number of purchase orders created during the selected period. |
End to end process
With the End to end process chart you can analyze the purchase order items and throughput times in more detail. You can create various contexts by selecting different categories from the drop-down list. The metric selector enables you to select different metrics.
The metric of the selector determines the value displayed on the bar chart. The following table describes the metrics.
| Metric |
Description |
Base |
| Number of items |
The number of unique purchase order items. |
Purchase order items |
| Avg. item value |
The average purchase order item value for the selected category. |
| Total item value |
The sum of the purchase order item values for the selected category. |
The average throughput time for the end to end process, from creating a purchase requisition to the actual payment for the related invoice. |
| Avg. throughput time PR creation to PR approval |
The average throughput time from the creation of a purchase requisition to the approval of the purchase requisition. Note: The throughput time is calculated only if both dates are available and occurred in the right order. |
| Avg. throughput time PR creation to PO approval |
The average throughput time from the creation of a purchase requisition to the approval of the purchase order. Note: The throughput time is calculated only if both dates are available and occurred in the right order. |
| Avg. throughput time PR approval to PO item creation |
The average throughput time from the approval of a purchase requisition to the creation of the purchase order item. Note: The throughput time is calculated only if both dates are available and occurred in the right order. |
| Avg. throughput time PR approval to PO approval |
The average throughput time from the approval of a purchase requisition to the approval of the purchase order. Note: The throughput time is calculated only if both dates are available and occurred in the right order. |
| Avg. throughput time PO creation to GR |
The average throughput time between the complete approval of the purchase order and the post of the receipt of the goods. Note: The throughput time is calculated only if both dates are available and occurred in the right order. |
| Avg. throughput time GR to INV item creation |
The average throughput time from the post of the receipt of the goods to the creation of the last invoice item. Note: The throughput time is calculated only if both dates are available and occurred in the right order. |
Metrics in the Purchase-to-Pay app template never take Purchase order items with missing data into account when the metric is calculated. For example, if a Purchase order item does not have a value for the selected category and the metric calculates the average over this category, the Purchase order item is not taken into account.
Trend
The graph on the Trend tab shows the metric values for the selected category over time.
Process graph
The process graph displays the end-to-end process based on the number of purchase order items.
You can use the Variants slider to change the number of activities and/or edges shown. Check out Working with process graphs.
You can select a different metric from the activity and edge metrics selector to display the process graph based on different metrics.The following tables describe the available metrics.
Activity metrics
| Metric | Description | Base |
| Number of items | The number of unique purchase order items created within the selected period. | Purchase order items |
| Avg. item value | The average value of purchase order items created during the selected period. | Purchase order items |
| Total Item value | The sum of the values of the purchase order items created during the selected period. | Purchase order items |
| Avg. event throughput time | The average throughput time for the end-to-end process. | Purchase order item end to end events |
Edge metrics
| Number of items | The number of unique purchase order items. | Purchase order items |
| Average throughput time | The average throughput time between the activities. | Process |
| Number of transitions | The number of transitions between the activities. | Process |
Submitting automation ideas
When you identify a bottleneck in the Purchase-to-Pay process while monitoring, for example when a manual activity takes a long time to be executed, you might want to send a request to automate the activity to Automation Hub. You can do this directly from the process graph. Check out Sending automation ideas to UiPath Automation Hub for more information.
This function is only available if Process Mining is set up for integration with Automation Hub.
