Uploading data
Introduction
Always make sure that the data is in the required format for the app template used for the process app. See App Templates.
When you create a new process app, you must upload data before you can publish the process app. You can also upload data for a published process app. In this case, the app will be published with new data.
You can use a sample dataset, upload a dataset with .tsv or .csv files, or load data using an extractor. See Selecting the data source.
When uploading data using the Upload data option, make sure the .csv or .tsv files have the suffix _raw.
Loading data for a published process app
Follow these steps to load data for a published app.
- Open the Process Mining portal.
- Go to the Process apps tab and locate the app for which you want to upload data.
- Select
on the process app card of the process app for which you want to ingest data and select Upload data.
Loading data using an extractor
The default extraction tool is CData Sync and it is recommended for any non-SAP source systems such as Oracle. For SAP, the recommended extraction tool is Theobald Xtract Universal.
When loading data using an extractor, note that tables that are uploaded once are not cleared when reloading data. If you want to clear a previously uploaded table, then re-upload a dataset with that table having 0 records.
CData Sync
If you want to load data from your source system directly into a process app in Process Mining, you can use CData Sync. CData Sync supports various source systems to which it can connect for data extraction for example files, databases, APIs, and so on.
Refer to Loading data using CData Sync for details.
For SAP source systems, the recommended tool is Theobald Xtract Universal. Theobald Xtract Universal provides fast data access and extractions to SAP ECC and SAP HANA data sources. Refer to Loading data using Theobald Xtract Universal for details.
DataBridgeAgent
DataBridgeAgent is only needed if you are migrating from an on-premises stand-alone Process Mining version. Only use DataBridgeAgent if you have a custom .mvp connector. Otherwise, use CData Sync, Theobald Xtract Universal for SAP, or files to upload data.
If you have a custom .mvp connector you can use the Process Mining on-premises (stand-alone) extractor DataBridgeAgent to load data for a process app in Process Mining. Refer toLoading data using DataBridgeAgent for details.
