Adding input tables
You can easily add input tables by uploading CSV files in the Data transformations editor. Adding an input table in the Data transformations editor does not trigger a new data run. This enables you to create the required SQL queries step-by-step when adding new input tables.
Follow these steps to add one or more input tables to the Input data.
- Select the Add file(s) icon
in the Input data section of the Data transformations editor. - Drag and drop one or more files that contain the data for the process app, or use the Select files option, to select the files from your computer.
- Check the detected details for your dataset in the Encoding and Delimiter list boxes**.** If needed, select the appropriate settings.
- Select Upload.
The files are uploaded and the new tables are added to the Tables list in the Input data section.
