Skip to main content
Configuring DataBridgeAgent
Introduction
This page describes how to configure DataBridgeAgent to load data for a process app in Process Mining.
Follow these steps to configure DataBridgeAgent.
  1. Download DataBridgeAgent. See Loading data using DataBridgeAgent.
  2. On the server, create a folder for the DataBridgeAgent. For instance, D:\processmining\P2P_data\.
    note
    In the remainder of this guide, we will refer to this directory as <EXTRACTORDIR>.
  3. Place the installation package in the <EXTRACTORDIR> folder.
    • Right-click on the installation package.
    • Select Extract All….
  4. Right-click on the file <EXTRACTORDIR>\datarun.json and select Open.
  5. Enter a value for the following settings:
    • azureURL
    • connectorWorkspace
    • connectorModuleCode
    • Input type
    • Use credential store
Generic parameters
The following table describes the generic parameters for DataBridgeAgent.
Parameter
azureURL
The SAS URL of the Azure blob storage to which the extracted data needs to be uploaded. See
Note: The azureURL is not used when loading data for use in Process Mining on-premises (Automation Suite). Make sure this field is left blank.
endOfUploadApiUrl
The API that is called to start data processing in Process Mining, once all data has been uploaded.
connectorWorkspace The name of the workspace of the connector used to load the data and to create the dataset.
connectorModuleCode
The module code of the connector used to load the data and to create the dataset.
Input type
Can be either:
SAP see SAP parameters CSV see CSV parameters ODBC see ODBC parameters
Note: depending on the preferred input type, you must enter the settings in the corresponding section.
Indicate whether or not a credential store is used for password storage.
Note: if set to true you specify the password identifier in de SAP Password or ODBC Password field.
Reporting currency
The currency in which price-related values are displayed.
Exchange rate type
The exchange rate type that is used for currency conversion.
Language
The language in which data is extracted from the source system.
Extraction start date
The start date of the extraction period of the data.
Note: In cases where only a subset of the data is needed, it is recommended to limit the amount of data loaded, while this may improve the loading times.
Extraction end date
The end date of the extraction period of the data.
SAP parameters
The following table describes the parameters that can be used for SAP datasources.
Parameter
SAP Host
The hostname or IP address of the SAP application server.
SAP SystemNumber
The two-digit number between 00 and 99 that identifies the designated instance.
SAP Username
The username of the account that is being used to log in to the SAP instance.
SAP Password
The password of the user above.
Note: If you use a credential store, you must enter the password identifier from the credential store, instead of the password.
SAP Client
The client that is being used.
CSV parameters
The following table describes the parameters that can be used for CSV datasources.
SAP SettingDescription
CSV Data pathData path in the Server Data that points to the place where the .csv files are stored. For example P2P/ if all files can be found in the folder named P2P.
CSV SuffixA regular expression containing the files extension of the file to read in. May contain a suffix up to 2 digits that are added to the name of the table.
CSV DelimeterThe delimiter character that is used to separate the fields.
CSV Quotation characterThe quote character that is used to identify fields that are wrapped in quotes.
CSV Has headerIndicate whether the first line of the .CSV file is a header line.
ODBC parameters
The following table describes the parameters that can be used for ODBC datasources.
Parameter
ODBC Driver
The name of the ODBC driver to use for this connection.
ODBC Username
Username to be used to connect to the external datasource.
ODBC Password
Password to be used to connect to the external datasource.
ODBC Connection parameters
Any other parameters are passed as specified to the ODBC driver. Use the format param1=value1 (;param2=value2)
Creating the dataset and upload it for use in Process Mining
To load the data and upload it to Azure for use in Process Mining you must run the EXTRACTORDIR\datarun.bat file.
The time taken for this task will depend highly on the data volumes loaded.
The output is uploaded to the SQL Server database using CData Sync for use in Process Mining on-premises (Automation Suite). See Configuring CData Sync.
Starting the file manually
Follow this step to start the data run.
  1. Double-click on the EXTRACTORDIR\datarun.bat file to start the data run.
Schedule a task for the data run
Instead of running the file manually, you can use Windows Task Scheduler to schedule a task that runs the batch script for automated data refreshes.
note
It is recommended to select the local SYSTEM user account for running the task and to select the Run with highest priority option in the Create Task window when creating the task in Windows Scheduler.
The output is uploaded to the SQL Server database for use in Process Mining Automation Suite.
important
If you add an interval for which there is no data available, the dashboards will show an error message.
Troubleshooting
The data run also creates a log file that can help in case of unexpected results or if the data upload with DataBridgeAgent fails. The file <EXTRACTORDIR>\datarun.txt contains the logs of the last data run.
