Create a job
important
The input data must meet the format as required for the app template you are using to create your process app. Refer to App Templates for details.
Follow these steps to create the extraction job.
- Create a new CData Sync job.
- Enter a descriptive name for the job in the Name field. For example, ServiceNow_to_AzureBlob or ServiceNow_to_SQLServer.
- Select the source connection created in Create a source connection the source connection from the Source list.
- Select the destination connection created in Create a destination connection from the Destination list.
- Make sure the option Standard is selected as the Replication Type and select Add Job.
- Go to the Task tab and select Add Tasks. Enable the Custom Query option.
- Create a Custom Query using the replication queries for your app template and select Add Tasks.
tip
You can copy the replication queries from the documentation for you app template that can be accessed from the list of App templates. Refer to App Templates.
- Edit the job Settings on the Overview tab. Enable the checkbox
Parallel Processingand enter8in the Worker Pool field to improve loading speed.- Locate the Destination schema entry and copy the schema retrieved in Create a Destination.
- Configure the Incremental Replication to make sure the Replicate Interval and Replicate Interval Unit are set so the resulting period is equal or larger than the extraction period. For example, if you want to extract data for a period of a year, the Replicate Interval and Replicate Interval Unit must reflect at least a year period.
- Go to the Advanced tab in the Settings panel and edit the Replicate Options. Enable Drop Table to prevent the data to be appended to the table.
- Save your changes.
Call the data run API
Follow these steps to edit the post-job event to call the data run API.
- Go to the Events tab in the Job Settings panel.
- Edit the Post-Job Event section and add the run API call from the code block ensuring to replace the
valueof the "http.url" with the End of upload API.<api:set attr="http.url" value="https://my-uipath-server.com/default/defaulttenant/processMining_/api/v4.0/apps/98dfd1d5-9e42-4f0e-9a0a-8945629f01b3/transform/unauthenticated"/>
<api:call op="httpPost" in="http"/>
Refer to Retrieving the SQL Server database parameters. 3. Save your changes. 4. Select Jobs and locate the destination job. 5. Run the job to test if the job runs correctly.
Logging information
You can add additional statements to obtain logging information on the API call. Follow these steps.
- Add the following statements in between the lines previously added in the Post -Job event.
<api:set attr="http.verbosity" value="5"/><api:set attr="http.logfile" value="D:/mydir/cdata_log.txt"/> - Edit the job Settings on the Overview tab and select Verbose from the Logfile Verbosity list box.
- Run the job and check the log file that is created.
