Deleting input tables
note
Deleting an input table removes the data for your process app. If you want to use the data in your process app at a later stage, you must re-upload the input table.
Follow these steps to delete an input table from the Input data list.
- Locate the input table you want to delete.
- Select the Remove table
table icon. A confirmation message is displayed. - Select Delete to delete the input table.
