Skip to main content
Editing dashboards
You can edit the dashboards of the open process app to customize the process app to your business needs. You can directly open the Dashboard editor which provides various options to create different views, and to organize, group, and filter data.
Follow these steps to open the dashboard editor.
  1. Go to the Development tab and locate the app you want to delete in the Process apps in development list.
  2. Select the edit application icon in the actions column. The Dashboard editor is displayed.
Check out Working with the dashboard editor.
tip
You can also select the Edit in dev mode option from the published process app menu to open the Dashboard editor.
