Editing app settings
General settings
If you have edit permission for an app, you can edit the app settings. For example, you can change the name of the app and/or the description. Furthermore, you can set data restictions for a process app, or define calendar settings.
Follow this step to open the app Settings.
- Open the actions menu for the app and select the Settings option.
The General tab of the Settings page is displayed where you can edit the App name and the Description.
Changing calendar settings
You must have edit permission for the app to select a different calendar type.
By default, the Gregorian calendar is used to display time-based data in dashboards. If your organization uses a different calendar, such as a financial or corporate calendar that does not align with the Gregorian calendar year, you can choose to use the Fiscal calendar option.
Follow these steps to change the calendar settings.
- Select the
icon and select Settings. - Go to the Calendar tab.
- If desired, enable the Fiscal calendar option.
- Select the applicable option from the Calendar type list.
- Configure the calendar type options according to your organization rules.
- Close the Settings page.
