Fields and metrics
With Data Manager you can add and edit fields and metrics displayed in your process app. You can also create new fields that derive their values from an expression or calculation based on values from other fields.
Terminology
- A Field is raw data—individual pieces of information tied to each row in your dataset. For example, a field might represent
PriceorQuantityfor each transaction in a table. Fields describe specific details of each row. - A Calculated Field is a transformation or computation applied to your raw data at the row level. It combines or modifies existing fields using formulas or expressions, creating new values for each row without aggregating data. For example,
Profitmight be a calculated field created by subtractingCostfromRevenuefor each row. - A Metric is a summary or an aggregation of data across multiple rows. Metrics combine data using methods like summing, averaging, or counting to create a high-level indicator of performance. For example,
Total Profit(sum of all profit) orAverage Quantity Sold(average of all quantities) are metrics that help provide insights into trends or overall performance. Once created, metrics can be reused across multiple charts and dashboards. Metrics can be used to calculate other metrics.
To summarize: (Calculated) fields provide detailed information row by row, while metrics summarize and aggregate data across multiple rows to help you see the bigger picture.
| Concept | Definition | Example | Data Level | Purpose |
| Field | Raw data tied to each row in the dataset. | Price, Quantity, Date | Row-level | Describe specific details of each row. |
| Calculated field | A field created from a computation applied to raw data. | Profit = Revenue - Cost | Row-level | Combine the values of existing fields. |
| Metric | A summary or aggregation of data across multiple rows. | Total Profit, Average Quantity Sold | Aggregated (multi-row) | Combine data using methods like sum, average, or count. |
Creating fields and metrics
If you want to add business logic to your process app but the field or metric you want to use is not available by default, you can create new data that you can use in your dashboards. This ensures that your dashboards provide the most valuable insights for stakeholders accross the busssiness.
Follow these steps.
- In the Data Manager panel, select +New, then select New field or New metric from the menu. The Create field or Create metric panel is displayed.
- Enter a descriptive name for the new field or metric.
tip
It is a good practice to refer to the goal of the field or metric, which means an indication of what is computed. For example,
Total_cost, for a field that which multipliesQuantitywithPrice_per_itemfor each order. (Total_cost = Quantity * Price_per_item). - If you create a new field, select the table into which you want to create the new field from the available tables in the Target table list.
important
A value is computed for each row of the selected table. References to fields in other tables are computed relative to the selected table. This means that referring to fields in other tables may yield duplicate results. You can only refer to fields which are reachable from the selected table. For example, you can use fields from the
Casestable when defining a new field in theEventstable, but not vice versa. The value of a field inCasestable is the same (duplicated) for each row in theEventstable that belongs to the same case. - Configure the business logic in the Logic configuration editor using the available logic blocks.
- Add the logic block for the operations.
- Add the fields and constants to define the operations.
tip
You can select the Preview button to view a sample of the values resulting from the calculation.
- Select Save.
note
The Save button is only enabled if the logic configuration is complete and correct.
The field or metric is added to the list of fields and metric in the Data Manager.
You can also create a new field for a specific table in the Data manager. Follow these steps to create a new field for a specific table.
- In Data manager, locate the table into which you want to create the field.
- Select the
icon to open the menu and select + Create new field.
The Create data window is displayed and the table is selected in the Tables field.
Adding logic blocks to the canvas
You can easily drag and drop logic blocks onto the Logic configuration canvas to build an expression.
When you create a logic flow or a calculation, the inputs and outputs of each logic block must match up correctly in terms of data kind. The expression is validated, and feedback is displayed on the logic block to help you to troubleshoot and correct the calculations as you go.
You can only save the logic configuration if it has no errors.
Drafts
Saving a logic block or configuration as a draft
You can save a logic block or configuration and reuse it later.
Follow these steps.
- Select the logic block you want to save as a draft, and drag it to the Logic blocks panel. The Logic blocks panels shows a Add block to draft area.
- Drop the logic block on the Add block to draft area.
The logic block is removed from the canvas and saved as a draft on the Draft tab.
Using a draft
Follow these steps to use a draft in your configuration.
- Go to the Draft tab and locate the logic block you want to use.
- Drag and drop the logic block to the desired location in your Logic configuration.
note
The draft is no longer available on the Draft tab.
Removing a logic block
Follow these steps to remove a logic block.
- Select the logic block you do not want to use anymore, and drag it to the Logic blocks panel. The Logic blocks panels shows a Delete block area.
- Drop the logic block on the Delete block area.
The logic block is removed from the canvas.
Editing field properties
This enables you to customize the dashboards by adapting them to the terminology used in your organization.Follow these steps to edit the properties of a field.
Select the field for which you want to edit the properties. The Edit field dialog is displayed.
Edit the Field name as desired.
Select Save.
Changing the field name
You can change the name of the fields. This enables you to customize the dashboards by adapting them to the terminology used in your organization.
Changing the field type
The field type indicates the kind of data that the field is intended to hold and therefore determines how the field can be used. There might be instances where the field Type does not align with the kind of data of the source field in your dataset. For example, you may upload data of an integer to a field that was previously uploaded with text. Such instances will be indicated in the Fields list in the Data manager.
For these fields, you can change the Type of the field.
You can only select a new Type based on the data kind of the source field that is uploaded. For example, if the field in the dataset is an integer, you can change the field to number**,** and if the field in the dataset is of text, you can change the field to nominal or ordinal.
You can only change the Type of a field that is not used in dashboards. In case the field is actually used in dashboards:
- Remove the field from the chart or charts.
- Edit the Type of the field.
- Add the field back on the chart or charts.
Currency format
For currency fields you can also change the currency format. The following illustration shows an example.
This is a display setting, it does not convert the field value.
Edit field dialog
The following table describes the elements of the Edit field dialog.
| Element | Description |
| Field name | The display name of the field. |
| Source field | The name of the column in the data source. |
| Type | The kind of data that the field holds. |
| Currency* | A drop down combo box containing all available currency formats. |
- Currency is only available for monetary fields.
Hiding and showing fields
With Data Manager you can hide fields that are available in your dataset but not used in your process app. A field that is set to hidden in Data Manager, will not be visible in selectors when editing dashboards using the dashboard editor. This is useful when you do not want to use these fields in a visualization, but do want to use them to compute metrics.
You can not hide a field that is used on a dashboard.
Follow these steps to hide a field.
- Locate the field you want to hide.
- Select the Hide field in app icon
icon The field is set to hidden and the icon is changed to the Show field in app icon
. If you select the icon, the field becomes visible again.
Editing custom fields
You can only edit the expression for custom fields you created from the Data Manager.
Follow these steps to edit a custom field.
- In the Data Manager panel, locate the field you want to edit and select the Edit icon.
The logic configuration of the field expression is displayed. - Edit the expression as desired and select Save.
The logic configuration editor is closed and you return to the dashboard editor.
Editing metrics
Follow these steps to edit a metric.
- In the Data Manager panel, locate the metric you want to edit and select the Edit icon.
The logic configuration of the metric expression is displayed. - Edit the expression as desired and select Save.
Context metrics
You can add context metrics to provide a better understanding of the main metric displayed on the chart. Context metrics are displayed as tooltips on charts.
The following illustration shows a chart with the main metric Average amount and Number of cases as a context metric.
Depending on the calculation of the main metric, different contexts may be useful to explain the main metric. For example, if the main metric is defined as Average amount, useful context is Number of objects for which the average amount is calculated. This also applies when you main metric is defined as Total amount. In this case, also Number of objects for which the sum is calculated is a useful context.
When your main metric is defined as a percentage, for example Cases with tag (%), useful contexts can be Number of objects with tag and Total number of objects.
The following table shows some examples of main metrics with relevant context metrics.
| Main metric | Context metric 1 | Context metric 2 | |
| Count | Number of objects 112 | - | - |
| Average | Average amount € 61,43 | Objects 112 | - |
| Sum | Total amount € 123.555,00 | Objects 112 | - |
| Percentage | Objects with tag % 60% | Objects with tag 600 | Total objects 1000 |
Deleting fields
To keep your data clean, you can delete fields that are not used anymore. Follow these steps to delete a field.
You can only delete empty fields.
- In the Data Manager panel, locate the field you want to delete.
- Open the actions menu for the field and select Delete field.
The field is removed without any notification.
Deleting metrics
To keep your process app clean, you can delete metrics that are not used anymore. Follow these steps to delete a metric.
In the Data Manager panel, locate the metric you want to delete.
Open the actions menu for the metric and select Delete metric. A confirmation message is displayed.
Select Delete.
noteYou can only delete user-created metrics. Metrics that are used in charts can not be deleted.
Viewing metric references
If you want to delete a metric that is used in charts, you must first delete the metric references. When you hover over the Delete metric icon, a popup is displayed indicating which dashboards and charts the metric is used in.
