Filters
Introduction
Filters can be created on dashboards and charts, and can be used to modify the information displayed on all dashboards. With filters, you can create subsets of your data to have a closer look at particular parts of the process.
Using multiple filters
When you add additional filters, you are further reducing the subset because you are applying more specific or additional criteria to be met. Only the data that meets all the filter criteria will be included in the final subset. In other words, multiple filters are combined as an AND in a logical statement where the data has to meet the conditions of Filter 1 AND Filter 2 AND Filter 3...so on, to be in the final subset.
Cross-filtering on dashboard level
If you make a data selection on a chart, this will automatically update the data in the other charts on the dashboard according to the data selection. The selection is a temporary filter that will be reset automatically when you leave the selection.
Also check out Data selections.
Timeframe filter
The Timeframe filter is a predefined and immovable filter. This Timeframe filter splits the data according to the selected date field of relevant items in the dashboard. For example, purchase order items or purchase order events for purchase orders created in the selected timeframe.
The Date field list contains all the fields of type datetime that are defined for your dataset. Depending on the dashboard context, the selected Date field will return relevant results.
You can set a timeframe filter and save it to a filter collection.
Selecting the previous or next timeframe
You can use the Next and Previous arrow buttons in front of the timeframe filter to navigate to the previous or next timeframe.
In this example the timeframe filter will be set to Document date: Oct 2020 if you select the previous timeframe, and to Document date: Dec 2020 if you select the next timeframe.
The Next and Previous arrow buttons are only enabled if your dataset contains data for the next or previous timeframe.
Last, Before, and After timeframe filter types
The Last timeframe filter type allows you to specify a timeframe that includes the most recent or last period in your dataset. For example, if you select Last 7 days, the filter will include data from the last 7 days available in your dataset. Note that this is not necessarily the data from the last 7 calendar days.
The Before timeframe filter type allows you to specify a timeframe for the period that includes all data before a specific date. For example, if you select Before January 1, 2024, the filter will include all data up until December 31, 2023.
The After timeframe filter option allows you to specify a timeframe that includes all data from a particular date until the current date. For instance, if you select After February 1, 2024, the filter will include all data from that date to today's date.
Case start, Case end, and Event end filters
| Filter | Description | Use case | Example |
| Case start (Purchase order item start, Sales order item start) | Filters the data according to the objects’ start date, and returns the objects that started in the selected period. | You want to filter for objects that start in October 2023. | Case start = October 2023 |
| Case end (Purchase order item end, Sales order item end) | Filters the data according to the objects’ end date, and returns the objects that ended in the selected period. | You want to filter for objects that end in January 2024. | Case end = January 2024 |
| Event end | Filters the data according to the events’ end date, and returns the objects that have events that ended in the selected period. | You want to filter for events that happen in 2023. | Event end = 2023 |
Fiscal calendar
If the Enable fiscal calendar option is selected, you can select the applicable calendar type from the list of available calendar types.
The fiscal calendar allows for better year-over-year comparison.
To use the fiscal calender in the Timeframe filter, the Use fiscal calendar option must be enabled in the Timeframe filter.
Offset calendar
When an offset calendar type has been configured for your process app, and you select the Year or Quarter option for the Timeframe filter, the data is displayed starting from the month as configured.
Defining a custom timeframe
You can select a custom timeframe to be used as the timeframe filter. All relevant items that have a date according to the selected date field within the defined timeframe are displayed in the dashboard.
Follow these steps to select a custom timeframe.
Select the Timeframe filter button.
Select the Date field you want to use for the timeframe.
Select the Type list box and select the Custom option from the list.
Select the From field and select the start date of the custom period you want to define from the date picker.
Select the To field and select the end date of the custom period you want to define from the date picker.
Filter panel
Process apps contain multiple advanced filter types. These filters can be added to the dashboard and used to modify the information displayed. You can add filters for analyzing in more detail in the Filter panel.
Follow these steps to display the Filter panel.
Select the Filter
icon.
The Filter panel is displayed. The Filter icon indicates if there are filters applied. ![]()
Hiding or showing the Filter panel
Follow this step to hide the Filter panel.
- Select the Filter
icon.
The Filter panel is hidden.
Follow this step to show the Filter panel.
- Select the Filter
icon.
The Filter panel is expanded.
Adding a filter
Follow these steps to add a filter.
- Go to the Filter panel.
- Select the Filter search bar.
A drop-down list with all the available filters is displayed. 3. Select the filter you want to add from the drop-down list.
If you want to add a particular filter, you can search for available filters.
Adding filter values
Follow these steps to add filter values.
- Select the filter to display the available values.
- Select the value or values you want to filter on.
The filter is added in the Filter panel.
Data selections
Selections in the dataset allow you to create a filter based on the information displayed in the dashboards. Selections can be triggered by dragging your mouse or by clicking on the graphs and charts. You can also select a chunk in a pie chart to create a filter on the values of the chunk.
Follow these steps to create a filter based on a data selection.
- Select the data you want to use to create a filter.
- Select the Filter by selected values icon on the chart, or click on any other chart in the dashboard.
A filter is added to the Filter panel.
If you do not want to create a filter from the data selection, you can select the Clear selection icon on the chart.
Percentage objects and events
The percentage graphics in the header bar display the percentage of objects and events for the applied filters. The following illustration shows an example.
If ~0% or ~100% is displayed, this indicates that the value is not exactly zero or 100, but that it rounded to 0 or 100.
Process filters
Depending on the process, a process-specific name is displayed to identify Objects, for example, Purchase order items, or Incidents.
Activity filter
The Activity end-to-end process filter enables you to select activities to filter on objects that include the selected activities.
When you select multiple activities from the process graph or activity list to filter by, this creates a filter on objects that include all the selected activities, rather than all objects that have any of the selected activities.
Filtering on objects that do not include the selected activity
If you want to filter on objects that do not include particular activities, you can select the Without option next the activity. The foillowing illustration shows an example.
Directly follows and Indirectly follows
With the Directly follows and Indirectly follows end-to-end process filters you can filter particular activity paths, meaning directly or eventually followed activities. This enables you to analyze objects in which activities follow a certain order.
When you select multiple activity groups, you create a filter on objects that go through all the selected activity paths, rather than all objects that go through any of the selected activity paths.
Creating a Directly follows filter
Follow these steps to add a Directly follows filter.
- Add a Directly follows filter in the Filter panel.
- Selectr +Add activity group.
- Select the activity that is the start of the activity path from Show objects where activity list.
You can start typing an activity name in the list field to search for a particular activity. 4. Select the directly following activity from the is directly followed by activity list.
Creating an Indirectly follows filter
Follow these steps to add an Indirectly follows filter.
- Add a Indirectly follows filter in the Filter panel.
- Click on +Add activity group.
You can start typing an activity name in the list field to search for a particular activity. 4. Select the directly following activity from the is eventually followed by activity list.
You can also create a Directly follows filter, or Indirectly follows filter, by clicking on an edge in the process graph and selecting the Filter by selected values option from the context menu.
If you want to filter on objects that do not follow a particular activity path, you can select the Without option for the Directly follows or Indirectly follows filter. The following illustration shows an example.
Starts with or Ends with
With the Starts with and Ends with end-to-end process filters, you can filter for objects that start or end with a selected activity. You can select the Without option if you want to filter for objects that do not start or end with the selected activity.
You can define multiple Starts with or Ends with filters. This allows you to filter on parallel activities by searching for objects that start with the specified activities as Starts with, or end with the specified activities as Ends with, respectively.
Rework filter
The Rework filter enables you to filter for objects that have rework, meaning that one or multiple activities are executed more than once in the process.
Follow these steps to create a Rework filter.
Add a Rework filter in the Filter panel.
Select the activity for which you want to filter the occurrences from the Show objects where activity list.
Use the Occurs .. times fields to select an operator (
<=,>=,=) and the number of occurrences to define the filter expression.
Process cropping filter
If you want to use the Process cropping filter for an existing process app, you must first optimize the process app. Refer to Optimizing an app for more information.
With the Process cropping filter, you can view a subset of the process. This enables you to zoom in to the process and analyze particular parts of the process in more detail.
You can use the Process cropping filter to check the throughput time between selected activities.
Follow these steps to create a Process cropping filter.
- In the Filter panel, add a Process cropping filter.
- Select the activity you want to use as the start activity for the subset from the list in the From field.
- Select the activity you want to use as the end activity for the subset from the list in the To field.
The process graph changes and only shows the activities that are part of the selection. The From <activity> will be the first instance, and the To <activity> will be the last instance of the process. The data in other charts and the KPIs on the dashboard are updated and only show the values related to the selection.
Filter types
List box
A list box filter allows you to select multiple values of a field.
When you have defined multiple filters, these can impact the selection of values that are visible in your list box filter. Some options in your list box filter might become unavailable based on the values of other filters. Unavailable values are also displayed in the list, but they are grayed out to indicate their unavailability at that time.
Select all / Deselect all
You can select the Select all option to select all the options from the list box in one click.
Invert
You can select Invert to change all unselected values into selected values, whereas all selected values will become unselected.
Additional search options for list box
If the field in the list box contains more than 20 options, the following additional search options appear.
| Option | Allows you to search for values that... |
| Contains | contain a specified string. |
| Starts with | start with a specified string. |
| Ends with | end with a specified string. |
These search options allow you to search for the filter values that you want to select from within a larger list of values.
With the Select all results option, you can select all the result values from the search at once, without having to individually select each value in the result.
Combo box
A Combo box filter allows you to only select one value of a field.
Range selector
A range selector is created for numeric fields and time ranges. This filter allows for a range to be selected. You can either drag the dots on the line to select a range, or enter the desired start and end values in the value fields.
For time ranges you can change the granularity of the selected range by selecting a different units from the drop-down lists. The following illustration shows an example.
Resetting filters
Clear all
The Clear all option in the Filter panel enables you to reset all the current filters. This means that any selections in advanced filters are cleared and all filters are removed from the Filter panel.
Follow these steps to reset all filters.
- Select the More icon
. - Select Clear all from the menu.
Resetting individual filters
Follow these steps to reset the values of an individual filter.
- Go to the Filter panel and locate the filter for which you want to reset the values.
- Select the reset icon
Removing individual filters
Follow these steps to remove an individual filter.
Go to the Filter panel and locate the filter you want to delete.
Select the delete icon
Filter collections
Introduction
When you have set one or more filters, you can save these filters in a filter collection. This enables you to quickly and easily navigate to your frequently used filters when analyzing data.
Creating a new filter collection
Follow these steps to create a filter collection.
- Add one or more filters.
- In the Filter panel, select the More filter actions icon to open the drop-down menu.
- Select Save as filter collection.
- In the Save filter collection dialog, enter a Name and a Description for the filter collection.
The filter collection is added in the Saved filter collections in the Filters list.
Changing a filter collection
You can change a filter collection, for example, by adding a new filter.
Follow these steps to change a filter collection.
- In the Filter panel, select the filter collection you want to change from the Filter search list.
- Add new filters or change the filters as desired.
- Select the Save icon next to the Filter search list field.
note
The Save icon is only visible if the filters in the filter collection have changed.
Managing filter collections
Follow these steps to manage existing filter collections.
- In the Filter panel, select the More icon next to open the drop-dwon menu
- Select Manage filter collections.
The Manage filter collections dialog is displayed. Here you can edit the Name or the Description for a filter collection, or you can delete the filter collection.
Changing the name or description of a filter collection
Follow these steps to edit the name and/or the description of the filter collection.
In the Manage filter collections list, locate the filter collection for which you want to change the Name or Description.
Select the Edit icon.
Edit the Name or Description as desired.
Deleting a filter collection
Follow these steps to delete a filter collection.
In the Manage filter collections list, locate the filter collection you want to delete..
Select the Delete icon.
Applied dashboard level filters
When you open a dashboard that contains dashboard level filters, the dashboard will display data according to the applied dashboard level filters. When one or more filters are defined for a dashboard, the
icon is displayed in the dashboard header.
You can select the icon to view the applied dashboard filters. The following illustration shows an example of dashboard level filters.
You can still add global filters in the Filter panel, which are applied on top of the dashboard filters. You cannot change the dashboard level filters.
Applied chart filters
When you open a dashboard that contains one or more charts with chart filters, those charts will display data according to the chart filters. When one or more filters are defined for a chart, the
icon is displayed at the top of the chart.
You can select the icon to view the applied chart filters. The following illustration shows an example of chart level filters.
You can still add global filters in the Filter panel, which are applied on top of the chart filters. You cannot change the chart filters.
