Input data
The input data panel shows the input tables that have been loaded into the process app as raw data. Select a table to see the fields and the data contents in the data preview. The data preview enables you to check if the input data looks as expected.
note
The preview shows 1000 records of data. If you want to filter for specific data, create a temporary debug query, refer to Data transformations.
note
The Preview panel shows the data of the last data run in which this table was recalculated. If you have made recent changes, then start a new data run to view its results, refer to Editing data transformations.
