Installing CData Sync
For information on installing and running CData Sync, refer to the official CData Sync - Getting Started documentation.
For more information on system requirements for CData Sync, refer to the official CData Sync - Installation and Configuration documentation.
For a POC, you can request CData for a Free Trial version of CData Sync. Go to the official CData Sync website to sign up and download CData-Sync - Free Trial.
To install CData Sync, you need a valid license. The license is provided via UiPath® for the purpose of Process Mining. If you already have a previous version of CData Sync installed, it is recommended to uninstall the previous version first. Any defined jobs/connections will be retained.
Follow these steps to install CData Sync.
- Download the CData Sync Windows installer (
setup.exe) using the following link: CData Sync Windows 25.2.9369. - Run the downloaded
setup.exeand accept the default settings.
If CData Sync is not started automatically in the last step of the installation, CData Sync can be reached at http://localhost:8181/. 3. Enter a password for the admin user.
After successful installation of CData Sync:
- Create a user account for each developer.
- Set up CData Sync to run as a service, to make sure CData Sync automatically starts up when booting the machine. Refer to the official CData Sync documentation for more information on how to run CData Sync as a service.
To set up an extraction using CData Sync, check out Loading data using CData Sync.
You can transfer a CData Sync license from one machine to another. Refer to the official CData Sync documentation for more information.
