Skip to main content
Merging event logs
tip
If you have multiple Event tables, these can be added to the data model one-by-one and they are merged automatically. Check out Viewing and editing the data model for more information on how to add tables. Alternatively, you can manually merge Event tables using the following queries.
If your event log is split over multiple event log files, you can merge the event logs into a single event log in Data transformations.
note
To merge multiple event logs, the Case_ID should point to the same object for all files. For example, all Case IDs are pointing to Sales Order IDs., such that Case_ID points to the same table for all event logs.
  1. Create a new app, based on the Event log app template.
  2. Use the Upload data option in the Selecting the Data Source step, and select the event log files you want to merge.
  3. Continue the Create new app wizard to create the app and to transform the data. The data run will fail and the Application status will show Run failed.
  4. Select View log to view the log file.
An error message displays indicating that the expected file is not found.
Error message 5. Go to the Data transformations editor. 6. For each input file:
  1. Create a .sql file with the same contents as the already available Event_log_input.sql.
Event_log_input.sql file 2. Adjust the file to select the required input fields and type cast them correctly. 3. Add the name of the new source tables to sources.yml.
Now all new input files can be combined into a single event log. :::note Make sure that the input files all have the exact same set of fields. ::: 7. Select the Event_log_input.sql file and replace the contents with:
-- The following code merges 3 input tables.
select * from {{ ref('Event_log_input_1') }}
union all
select * from {{ ref('Event_log_input_2') }}
union all
select * from {{ ref('Event_log_input_3') }}
note
Adjust the code to match the names of the input tables needed.
  1. Select Apply to dashboards to run the data transformations and make the resulting table available for use in the dashboards.
