Skip to main content
System requirements
Introduction
Process Mining on Automation Suite requires a separate Microsoft SQL Server for the AutomationSuite_ProcessMining_Warehouse for data storage for Process Mining process apps. This page provides hardware requirements and recommendations for setting up a Microsoft SQL Server machine for AutomationSuite_ProcessMining_Warehouse.
note
Both Microsoft SQL Server Enterprise and Microsoft SQL Server are supported for Process Mining.
note
Recommendation Using a Multi-AZ Amazon RDS instance is recommended, but you can use a Single-AZ Amazon RDS instance for Process Mining.
Check out Configuring Microsoft SQL Server. For more information on how to manually add Process Mining in the cluster.json configuration file check out Manual: Advanced installation experience.
Refer to Software requirements for the requirements to access the UiPath Platform.
Browser compatibility
For an optimal browsing experience when working with Process Mining, we recommend using Google Chrome, Microsoft Edge Chromium, or Mozilla Firefox.
note
Process Mining may experience performance issues with Safari.
CData Sync
For more information on system requirements for CData Sync, refer to the official CData Sync - Server Administration documentation.
Before you begin
To calculate the hardware requirements, you need to have an indication of:
  • the number of (million) events in your process.
  • the number of case and event fields in your output data.
    note
    In a development environment, for performance reasons, it is recommended to work on a small development dataset with a limited number of records.
note
To check the dependencies with other products, go to the Cross-product dependencies page in the Automation Suite guide.
Capacity calculation
You can use the UiPath Automation Suite Install Sizing Calculator to determine the hardware requirements for setting up a dedicated Microsoft SQL Server machine for Process Mining. When you add Process Mining to the Product section, the minimum requirements for 1 Dedicated SQL Server are displayed. The following illustration shows the Automation Suite Install Sizing Calculator.
Capacity calculator
Follow these steps to calculate the recommended requirements for setting up a dedicated Microsoft SQL Server machine for Process Mining.
StepAction
1Go to the Capacity Calculator.
2Click on Change Product Selection.
3Select the Process Mining option button in the list of Products and click on Add to add Process Mining to the Product selection.
4Click on Process Mining in the Product selection.
5Enter the appropriate values for Number of Events In Millions and the Number of Case and Events Fields.
The following illustration shows an example.
Capacity calculator
CPU (cores)
The number of CPUs needed depends on how much of the transformations can be executed in parallel and the number the concurrent data runs. In case of performance problems with a many concurrent users, consider increasing the number of CPU cores and RAM.
RAM
There must be enough RAM available for having both input data and output data in memory.
Disk space (GB)
The required disk storage depends on the number of transformation steps needed from raw data to output data of the connector.
SQL Server tempdb database size
The SQL Server tempdb database must be big enough to fit all the data. Otherwise, a transformation run cannot be completed successfully.
