Custom process input fields
Introduction
If your data for cases and events is split up into different input files, you use the Custom process app template.
If you want to create a new Custom process app, you must upload a dataset that contains the data to be used in the process app.
For each table, this must be a tsv (tab-separated) file or .csv (comma-separated) file that contains a column for each input field.
This section contains an overview of the input tables for Custom process. For each field, the name, the data type, and a short description are displayed. Apart from that, it is indicated whether the field is mandatory.
Table names and field names are case-sensitive. Always make sure that the field names (column headers) in your dataset match the field names (in English) in the following tables and that the file names match the table names.
Mandatory and optional fields
Your input data file can have different fields or different field names. However, some fields are mandatory, which means that the data must be available in your input data file for a correct working of the process app.
When a field is mandatory, it should not contain NULL values.
Field types
The following table describesthe different field types and their default format settings.
| Field type | Format |
| boolean | true, false, 1, 0 |
| datetime | yyyy-mm-dd hh:mm:ss[.ms], where [.ms] is optional. Refer to the official Microsoft documentation if you want to change the date format. |
| double | Decimal separator: . (dot) Thousand separator: none |
| text | N/A |
| integer | Thousand separator: none |
Cases_raw
The Cases_raw table contains the detailed information for the status, type, value and description for the related case.
| Name | Data type | Mandatory Y/N | Description |
Case_ID | text | Y | The unique identifier of the case the event belongs to. |
Case | text | N | A user-friendly name to identify the case. |
Case_status | text | N | The status of the case in the process. For example, open, closed, pending, approved, etc. |
Case_type | text | N | The categorization of the cases. |
Case_value | double | N | A monetary value related to the case. |
Event_log_raw
The Event_log table contains information on the activities executed in the process.
Activity | text | Y | The name of the event. This describes the step in the process. |
Event_end | datetime | Y | The timestamp associated with the end of executing the event. |
| Event_ID | integer | Y* | The unique identifier of the event. |
Automated** | boolean | N | Indicates whether the event is manually executed or automated. |
Event_detail | text | N | Information related to the event. |
Event_start | datetime | N | The timestamp associated with the start of executing the event. |
Team | text | N | The team that executed the event. |
User | text | N | The user who executed the event. |
*) Event_ID is optional, but is mandatory if you want to use Due dates.
**) Automated is part of the input data. However, if you need to derive whether an event is automated or not, you need to customize this in the data transformations to create that logic based on the required information. It is recommended to do this in the Event_log.sql file. Locate the statement that contains ...as "Automated" and replace it, for example, with a statement as displayed in the following code example.
case when Event_log_base."User" = 'A' then pm_utils.to_boolean('true') else pm_utils.to_boolean('false') end as "Automated"
Event_cost and Event_processing_time
Event_cost and Event_processing_time used to calculate Automation potential are not part of the input data. You can configure these fields in Data transformations using SQL statements. Check out Configuring fields for Automation potential for more information.
Tags_raw
The Tags_raw table contains fields for tags that are defined in your process. If you upload tags, the Tags dashboard will be enabled.
Tags_raw is an optional table.
Case_ID | text | Y | The unique identifier of the case the tag belongs to. |
Tag | text | Y | A user-friendly name to identify the tag. |
Tag_type | text | N | The category to which the tag belongs to. |
Due_dates_raw
The Due_dates_raw table contains fields for due dates that are defined in your process. If you upload due dates, the Due dates dashboard will be enabled.
Due_dates_raw is an optional table.
Event_ID | integer | Y | The unique identifier of the event the due date belongs to. |
Due_date | text | Y | The name of the due date. |
Actual_date | datetime | Y | The actual moment the event associated with the due date happened. |
Expected_date | datetime | Y | The moment the event associated with the due date was expected to happen. |
