Skip to main content
Uploading data
Introduction
important
To upload data for a process app, you need to have consumption units on your account.
note
Always make sure that the data is in the required format for the app template used for the process app. Refer to App Templates.
When you create a new process app, you must upload data to publish the process app. You can also upload data for a published process app. In this case, the app will be published with new data.
You can use a sample dataset, upload a dataset with .csv files, or load data using an extractor. Check out Selecting the data source.
Loading data for a published process app
Follow these steps to load data for a published app.
  1. Open the Process Mining portal.
  2. Go to the Process apps tab and locate the published process app for which you want to upload data.
  3. Select the Open menu icon on the process app card and select Upload published app data.
The Upload published app data page is displayed where you can select the data source for your data.
important
When you upload data for a published process app, you can only upload new data for an existing table. The input data settings are read-only, and you can not make any changes to the mappings in the Tables and Fields pages. You can not upload new data that is not part of the data model of the process app.
Loading data for a process app in development
  2. Go to the Development tab and locate the process app for which you want to upload data.
  3. Select the Open menu icon in the actions column and select Upload dev data.
The Upload dev data page is displayed where you can select the data source for your development data.
Loading data using an extractor
The default extraction tool is CData Sync and it is recommended for any non-SAP source systems such as Oracle. For SAP, the recommended extraction tool is Theobald Xtract Universal.
important
When loading data using an extractor, note that tables that are uploaded once are not cleared when reloading data. If you want to clear a previously uploaded table, then re-upload a dataset with that table having 0 records.
CData Sync
If you want to load data from your source system directly into a process app in Process Mining, you can use CData Sync. CData Sync supports various source systems to which it can connect for data extraction for example files, databases, APIs, and so on.
Refer to Loading data using CData Sync for details.
For SAP source systems, the recommended tool is Theobald Xtract Universal. Theobald Xtract Universal provides fast data access and extractions to SAP ECC and SAP HANA data sources. Refer to Loading data using Theobald Xtract Universal for details.
DataBridgeAgent
important
DataBridgeAgent is only needed if you are migrating from an on-premises stand-alone Process Mining version. Only use DataBridgeAgent if you have a custom .mvp connector. Otherwise, use CData Sync, Theobald Xtract Universal for SAP, or files to upload data.
If you have a custom .mvp connector you can use the Process Mining on-premises (stand-alone) extractor DataBridgeAgent to load data for a process app in Process Mining. Refer toLoading data using DataBridgeAgent for details.
